Author Topic: V2.0.6 for ME500X2, MED450X2, MED400X2 Series 23March  (Read 13816 times)
Administr8or
Online Online
« on: March 24, 2012, 01:54:04 pm »
Release V2.0.6 with TV Series XML Wall and Music Player / Music Jukebox Fan Art support
XXXXXXXXXXXXXXXXXXXXXX  XXXXXXXXX URGENT NOTICE XXXXXXXX     XXXXXXXXXXXXXXXXXXXXX
It has come to our attention that this version may corrupt data on a local Hard Drives (Not Network) under certain conditions and we strongly suggest that you use V2.0.4 or V2.0.7.
V2.0.7 Download
http://www.mede8erforum.com/index.php/topic,8327.0.html
TV Series XML Wall
Fanart Music Player
Due to slight hardware differences we have made dedicated firmware releases for the Europe Region and the International Region. We suggest that you firstly update the firmware to the correct region to where your Hardware was purchased. If you experience any difficulties regarding the reading of the Internal Hard Drive or the non Booting of the internal PCIe WiFi you are welcome to try the other Regions firmware.  The European Version will read as 2.0.6 in the Setup --- Info and the International version will read as V2.0.6 (NOP)
V2.0.6 23March2012
Change log
1) New Mede8er TV Series XML Wall
2) Support for fanart.jpg in Music Player / Music Jukebox and any folder – size 1280 x 720 pixels
3) Fixed Subtitle issue reported in this thread http://www.mede8erforum.com/index.php/topic,8135.msg51362.html#msg51362
4) Added support for extensions  .ts1  .ts2 .ts 3  etc etc
5) Fixed the stopping of music when doing a 'Return' in Music Player / Music Jukebox Player
6) Fixed 'Audio' button return to 'currently playing' music
7) Fixed  - Facebook Image causing X2 crash / freeze
Cool Now auto switch NAS 'off' and back 'on' for 'Music Scan' and 'Set to Skin' function
9) Fixed Internet and YouTube after NFS
10) Fixed Forward / Back Skip in Music Player when playing Flac files
Demo Pack
You can download an internal demo pack 'Series - Demo_12March2012.rar' that might well be worth downloading and testing as this will give you a feel for this new functionality. PLS DO NOT TRY TO PLAY THE VIDEO FILES AS THEY ARE ACTUALLY TXT FILES RENAMED.
http://www.mede8er.org/artwork/temp/Series - Demo_12March2012.rar
TV Series XML Wall Teaser
http://www.mede8er.org/artwork/temp/Mede8er_TV_Series_XML_Wall.mp4
Music Jukebox User Guide - Updated 23 March2012
http://www.mede8er.com/mede8er_music_jukebox_user_guide.html
Music Player with Fanart Teaser
http://www.mede8er.org/artwork/temp/Mede8er_Music_Player_Fanart_Demo.mp4
You can use ThumGen with a Mede8er Profile to scan your Series in order to create the images and xml files   http://thumbgen.org/
Mede8er XML Series Wall  Profile Download
http://www.mede8er.org/beta/Firmware_Final/MED500X2/Mede8er TV Series XML Wall_12March2012.zip
Mede8er TV Series XML Wall explanation
Organizing TV Series for Media Players can be very challenging and time consuming if you intent to have Image and Episode support in terms of Plot info etc. We have designed the new TV Series XML Wall to be easy to use in conjunction with a well respected scraper called Thumbgen. The fact that it is not html based means that the user can easily change Plots, Images and Fanart without messing up the main structure. Thumbgen in conjunction with the Mede8er Profile will do all the following for you with the exception of Point4
1)   Thumbnail images ideal size = 160 x 237 pixels
2)   If you place a Series.jpg image 160 x 237 pixel in each episode folder then it will be applied to all thumbnails in the folder
3)   A Folder.jpg 160 x 237 can be used if you want to show a different image from outside the folder
4)   You can change each thumbnail image individually if you require to do so  - Just name the image with the same name as the video file – the extension must remain .jpg
Eg
american.idol.s10e30.720p.hdtv.x264-orenji.mkv
5)   Thumbgen will automatically make the correct Episode xml  --  basically each video file requires its own xml file
eg
Band Of Brothers_2001 - E01 - Currahee.mkv
Band Of Brothers_2001 - E01 - Currahee.xml
Instructions for the use of Thumbgen to scrape xml and images for the TV Series XML Wall
1) Download and Install Thumbgen http://thumbgen.org/
2) Download the Mede8er Profile and unzip it.  Copy the file 'Mede8er Profile 'Mede8er TV Series XML Wall_12March2012.tgp' to the Profile folder in Thumgen
http://www.mede8er.org/beta/Firmware_Final/MED500X2/Mede8er%20TV%20Series%20XML%20Wall_12March2012.zip
3) Open Thumbgen and select the Profile on the Top Left  ' Mede8er TV Series XML Wall_12March2012'
4) Select Process Files / Folder
5) Navigate to the Folder you want to scan and select it
6) Now go to 'Create Sheets/ thumbnails' and select a scanning option
7) Thumbgen will do the scraping and copy the correct files to the folder you select.
Fanart Explanation
You can use a Fanart.jpg 1280 x 720 pixel in any folder and it will be supported including the Video Jukebox. Fanart is really nice in the music player and you need to experiment a little. I suggest you find suitable images with Google and select the filter to show Images and select the size filter to 1600 x 1200 and then use Photoscape or any image package to crop the image to 16:9 and re-size it to 1280 x 720.
Download Photoscape -- http://www.photoscape.org/ps/main/help.php?id=intro
USER MANUALS
MED500X2
http://www.mede8er.com/images/USER_INSTRUCTIONS/Mede8er_med500x2_user_rev5.0.7_24Dec2011.pdf
MED450X2
http://www.mede8er.com/images/USER_INSTRUCTIONS/Mede8er_med450x2_user_rev1.05_24Dec2011.pdf
MED400X2
http://www.mede8er.com/images/USER_INSTRUCTIONS/Mede8er_med400x2_user_rev2.5_24Dec2011.pdf
AFTER THE UPDATE WE SUGGEST YOU UNPLUG AND REBOOT THE X2 AND THEN CONTINUE
If you installing a new Hard Drive then it should be formatted in the X2 for correct operation. After the format the Hard Drive should be shown as HDD: in the Media Library. (Not the Devices Page) If it not shown as HDD then you must format the Hard Drive a second time)
Emergency Procedure
PASSWORD PROTECT NETWORK SHARES -- NAS SETUP
Use the My_Shortcuts method as shown in this demo http://www.mede8er.com/Mede8er_X2_Add_Shortcut.html
PUBLIC SHARES -- PC / NAS
Username:  Guest
Password: Guest
IP:  xxx.xxx.xx.xx
« Last Edit: May 05, 2012, 11:51:54 am by Mede8er1 » Logged
