Pages: [1] 2   Go Down
Author Topic: RCA audio outputs not working after firmware update  (Read 3833 times)
KaiserRaath
« on: March 17, 2012, 07:32:29 pm »
I updated my firmware to version 1.6 today and the RCA audio stopped working. I have a Med250X, and I use the HDMI for video (and now for audio too), and used the RCA for external audio successfully on version 1.5.
I have reset to default settings but it didn't work. Any suggestions?
« Reply #1 on: March 17, 2012, 08:22:07 pm »
Do you have the audio output set to max on your mede8er?
It might be set to low output.
KaiserRaath
« Reply #2 on: March 17, 2012, 10:12:45 pm »
Yes, volume set to max, not a sound  Undecided
« Reply #3 on: March 18, 2012, 10:47:28 am »
Did you already downgrade to 1.5 to verify you get the sound back on RCA again?
Or another suggestion:
Install 1.6 again to verify you don't have a bad flash install.
KaiserRaath
« Reply #4 on: March 18, 2012, 11:51:16 am »
Okay, thanks, I will try 1.6 again, and if that fails I will try a downgrade to 1.5.
KaiserRaath
« Reply #5 on: March 18, 2012, 12:43:12 pm »
Okay.
Reloaded 1.6 and still no audio.
Loaded 1.5 and the audio is back.
Another thing I noticed, is that the internal HDD is listed under USB, together with the other USB devices, on firmware 1.6, but on 1.5 it is listed separately as a hard disk.
File copying from host USB port (portable HDD or flash disk) to internal HDD works on 1.6, but not on 1.5.
« Reply #6 on: March 18, 2012, 01:27:17 pm »
Another idea, did you try the Thai version?
Do you see the same with that one?
MED250X INTERNATIONAL VERSION
http://www.mede8er.org/beta/Firmware_Final/MED250X/MED250X_V1.6_28Feb2012.zip
MED250X THAI VERSION
http://www.mede8er.org/beta/Firmware_Final/MED250X/MED250X_V1.6_28Feb2012_Thai.zip
KaiserRaath
« Reply #7 on: March 18, 2012, 06:56:08 pm »
I just tried the Thai version of firmware version 1.6, and it also doesn't work  Sad
Back to 1.5 again.
Administr8or
« Reply #8 on: March 18, 2012, 07:16:06 pm »
KaiserRaath
Tested my MED250X sample and it seems fine with V1.6. Will test some stock units tomorrow and report back
« Reply #9 on: March 18, 2012, 10:17:40 pm »
Hi KaiserRaath,
Can you post full details of your firmware info screen in setup, including the bootrom version on your unit?
KaiserRaath
« Reply #10 on: March 19, 2012, 08:42:04 am »
Sure, I can get that for you tonight Smiley
Administr8or
« Reply #11 on: March 19, 2012, 03:28:01 pm »
KaiserRaath
We tested some MED250X units at the office with V1.6 and they work as per spec. Maybe you need to bring your unit in for testing.
Sanji Electronics (Pty) Ltd
12 Saddle Drive,
Woodmead Office Park, Woodmead, Gauteng,
South Africa.
Tel: +27 11 202 8160
Google Maps
http://maps.google.co.za/maps?q=12+Saddle+Rd,+Woodmead,+Sandton,+City+of+Johannesburg,+Gauteng+2191&hl=en&ll=-26.047077,28.089831&spn=0.007085,0.008937&sll=-28.45,24.7&sspn=28.196234,36.606445&oq=12+saddle+drive+woodmead+&geocode=FZiNcv4d5p2sAQ&hnear=12+Sa
KaiserRaath
« Reply #12 on: March 21, 2012, 10:06:13 am »
@Maasbommel
I am on 1.5 now, compiled Nov 28 10:14:10 2011, Bootloader 0000.0302.0015
@Mede8er1
I'll make a plan to bring it in, thanks Smiley
JohnGape
« Reply #13 on: May 04, 2012, 09:04:40 pm »
I have also just upgraded to v1.6 and I got the same problem. Did you find a solution to the issue or its best to just stick to version 1.5?
TALON
« Reply #14 on: July 04, 2012, 09:35:58 pm »
I updated my firmware to version 1.6 today and the RCA audio stopped working. I have a Med3000X.
After downgrading to Ver 1.4 (I couldn't UnRAR ver 1.5) and my sound came back straight away.
Pages: [1] 2   Go Up
