Author Topic: Lyrics for mp3 songs  (Read 622 times)
Frankrose
« on: July 02, 2012, 12:40:15 pm »
My wife and I would like to see the Lyrics for some of our music,
 is there any way this can be created on the 500x2?
« Reply #1 on: July 02, 2012, 01:00:10 pm »
Automatically?  You might find some kind of site which hosts Kareoki videos..where the video displays the lyrics. But if you  thinking of some kind of DSP which  extracts the "voice" from any music file and runs it through a speech  to text convertor..then No.
If it could be done for muisc..I;m sure that movie buffs would love it if it also included language translation as well.
Frankrose
« Reply #2 on: July 02, 2012, 01:06:45 pm »
We would like just to see all the Lyrics on a sheet, does not need to be time with song
« Reply #3 on: July 02, 2012, 01:14:09 pm »
You are free to exit the Muisc Jukebox, if you don't start it from a Favourite. You could then browse to a folder of jpgs containing the lyrics...but you would have to locate them on the web and put them there.
Frankrose
« Reply #4 on: July 02, 2012, 01:20:28 pm »
I all ready have a number of Lyrics in file on the computer, some I have tried pasting in tagscanner.
I have saved them in two types of formats Irc and txt. Can I load the Lyrics when I play a track?
« Reply #5 on: July 02, 2012, 01:40:26 pm »
There is no such embedded function.  All you can do is play music and browse images.The only text formats supported are movie subtitles.
Frankrose
« Reply #6 on: July 02, 2012, 01:44:54 pm »
His there a way to create a image from my Lyric text and diplay on the screen like a back drop?
« Reply #7 on: July 02, 2012, 01:56:54 pm »
Only as a background to the player..so it would be covered by the player graphics.
Frankrose
« Reply #8 on: July 02, 2012, 02:00:21 pm »
So can the player  graphics be removed and if so how?
« Reply #9 on: July 02, 2012, 02:35:04 pm »
No. The player is designed for those who  want to select music and listen.  so there is lots of eye candy during the slection process...and then just the simple screen saver after that.  If anything , we get more posts about playing muisc without the Tv on than doing something else with the video output during muisc play.
