Author Topic: MED500X2 Has Random Freezes  (Read 481 times)
Jebedia
B8a Tester - X2
« on: March 19, 2012, 10:09:28 am »
I'm a huge fan of the Mede8er. I had a MED500 for about three years but it was stolen a month ago. Luckily my insurance replaced it with a MED500X2...
The new mede8er came with a pre-installed 1Tb Hard Drive.
The new X2 has many great new features and additional functionality, Awesome. Except it's slow while navigating through the menus.
I've also had multiple freezes. At least three or four a day!
This happens at random times, while navigating through the menus, using the delete function or when it has the screen saver on and I reactivate it with the remote.
When the freezes happen I have to reboot using the power cable. This is annoying.
I've installed the latest firmware but this has had no effect.
I'm used to the speed and reliability of the old MED500 so I expected at least the same if not better from the new MED500X2.
Does anyone have any ideas on what could be causing the slow speed and freezes?
« Reply #1 on: March 19, 2012, 11:10:06 am »
The code is more complex...and the faster processor dosn't compensate. The freeze issues you mentioned where a big problem with 2.0.4 developement.  you should upgrade to  2.0.4/2.0.5 to get the benefit of changes which addressed the issue.
Jebedia
B8a Tester - X2
« Reply #2 on: March 19, 2012, 12:39:18 pm »
Thanks, That explains the Slower speeds and I can livewith that. It's the freezes that are realy annoying.
I formated the hard drive using the Mede8er and upgraded the FW to 2.0.5 the day I recieved the new machine so it's been freezing with the new FW.
Any other ideas?
« Reply #3 on: March 19, 2012, 12:53:44 pm »
Is the NAS on?  Which version of firmware did you install?
« Last Edit: March 19, 2012, 01:03:04 pm by jer1956 » Logged
Jebedia
B8a Tester - X2
« Reply #4 on: March 19, 2012, 01:45:20 pm »
I Installed 2.0.5
I dont have a nas storage device so I did not activate it.
Is it activated by default?
Administr8or
« Reply #5 on: March 19, 2012, 02:08:02 pm »
Jebedia
1) What Firmware Version did you install EU or Int ??
2) Do you have images from Facebook on your Hard Drive or Network?
Jebedia
B8a Tester - X2
« Reply #6 on: March 19, 2012, 02:33:07 pm »
I installed the International Version.
No face book images.
« Reply #7 on: March 19, 2012, 02:38:16 pm »
I Installed 2.0.5
NAS is the Samba server for sharing your internal hard drive over the network. 2.0.5  has new NAS code which also manages screensaver and spin down problems (because it suffered the most from them) ..which  can make a system more stable.
Jebedia
B8a Tester - X2
« Reply #8 on: March 19, 2012, 02:59:57 pm »
So by activating it I should have more stability?
« Reply #9 on: March 19, 2012, 03:00:52 pm »
Yes.
Jebedia
B8a Tester - X2
« Reply #10 on: March 19, 2012, 03:09:09 pm »
I'll give it a try tonight.
Thanks for the advice.
