Author Topic: MED250X Firmware Update V1.6 -- 28 Feb 2012  (Read 18357 times)
« on: March 01, 2012, 05:24:49 AM »
New update for MED250X
If you do not have a unrar program you can download Free program Rarzilla
Download RarZilla Free Unrar
MED250X INTERNATIONAL VERSION
http://www.mede8er.org/Firmware_Final/MED250X/MED250X_V1.6_28Feb2012.zip
MED250X THAI VERSION
http://www.mede8er.org/Firmware_Final/MED250X/MED250X_V1.6_28Feb2012_Thai.zip
MED250X CHINESE VERSION
http://www.mede8er.org/beta/Firmwares_Beta/MED250X/V1.6%20CH/MED250X%20V1.6%20CH.rar
Changelog V1.6
1) Fixed 'error' when Deleting or Coping in the File Manager
Changelog V1.5
1) Fixed Alpha sorting on USB fat32 Drives
2) Changed screensaver image
3) Selection of Font A or B in Setup Menu
4) Fixed aac sound in MOV file
Update Procedure
UnZIP or UnRAR the file and you will find one file named install.img. Copy this file to the root directory of a Flash Drive. Plug the flash drive into the Mede8er. Disconnect the power jack at the rear of the Mede8er then plug it back in - Now press the on/off button on the Mede8er (not the remote) and hold it pressed for 10 seconds and then release.
After approximately 15 seconds the LED on the Mede8er with flash red-blue and you will get a display of the progress of percentage installed on your TV display (some TV's will not display this) wait until the Mede8er re boots itself +- 180 sec. You Mede8er is now be updated.
« Last Edit: May 15, 2014, 06:13:28 PM by Mede8er1 »
