Pages: [1] 2   Go Down
Author Topic: Med500X2 freeze  (Read 1401 times)
cilpet
« on: February 23, 2012, 02:38:55 pm »
Since Jer advised me to post here ...
I have my MED500X2 for about a month and i noticed the player freezes quiet often (about 15 times so far) and i needed to do hard reset (plug out-in power suplly).
Mostly this happend at playing mp3 music from installed hard disc ( interesting is that music keeps playing, while the med8er does not respond to remote or pressing ON-OFF button )  ,  watching You Tube. Not to mention internet surfing. I never succeed to log into Facebook .
Also i noticed the player reacts much slower then the old one at moving through menues.
While on the other side at  playing movies ( even 3D ) didn't found any problems . Nor at internet radio playing.
Very disapointed regarding my old 500.
Any advices what to do?
My setup :
Med500X2 with keyboard - 2.0.3 firmware
TV Panasonic – VT50 – connected via hdmi to player
Receiver Pioneer VSX – audio conected to TV via optical input since reciver does not have hdmi input.
Wired and stabile network through Linksys 54GL
« Reply #1 on: February 23, 2012, 03:07:38 pm »
Did you buy a complete package..or move the drive from the 500x?
cilpet
« Reply #2 on: February 23, 2012, 03:12:19 pm »
I moved drive from 500x and formated as i was advised here on the forum. It is 1TB WD...right now i don't know which model is. I transfer all the movies from my PC to this disk and all are playing without any problem, so i don't know why would this have effect on playing mp3-s.
« Reply #3 on: February 23, 2012, 03:37:43 pm »
If you  go into medilibrary/HDD..does the file location line under the main screen..show HDD1: or C:?
« Reply #4 on: February 23, 2012, 05:40:20 pm »
I suggest to check if your mp3 files have large embedded covet art. There is a program mentioned in my beginners guide to easy check/reduce embedded mp3 cover art. This might solve your hung issue.
cilpet
« Reply #5 on: February 23, 2012, 06:30:58 pm »
Hard disc shows as HDD:  , but on the computer i see him as HDD1.
Model of hard disc : WD10EARS.
Fan on the player is working normally. I tried with facebook again and it freeze again.
I can try this without hard disc connected ?
« Reply #6 on: February 23, 2012, 06:35:07 pm »
Unreliabilty of web services is often down to using the wrong DNS server.
You will find advice on such  issues here:-
http://www.mede8erforum.com/index.php/topic,7564.0.html
cilpet
« Reply #7 on: February 23, 2012, 07:41:43 pm »
I just changed the DNS from 192.168.1.1 ( Router IP) to 127.0.0.1 but it frozen at about 77% of loading fb. Player is dead to any control now. I can still browse and play contents on players disc through my PC.
« Reply #8 on: February 23, 2012, 08:03:40 pm »
Did you give you new box a new network name?  Did you shutdown the  network to allow it to refind the new med?
« Reply #9 on: February 23, 2012, 09:01:19 pm »
Please also look at my remark re mp3 files and large embedded cover art.
cilpet
« Reply #10 on: February 23, 2012, 09:45:08 pm »
Jer1956 -> I did everything as you suggested , but the results are still same. All other sites loaded normally ( Google...) except Facebook always stuck.
Maasbommel -> Can't find ...  "I suggest to check if your mp3 files have large embedded covet art. There is a program mentioned in my beginners guide to easy check/reduce embedded mp3 cover art. This might solve your hung issue."
Thank you for all your help so far.
« Reply #11 on: February 23, 2012, 10:24:29 pm »
http://www.mede8erforum.com/index.php/topic,5481.0.html to reduceren internal cover art.
cilpet
« Reply #12 on: March 03, 2012, 11:47:24 am »
I was waiting for new firmware.
Same old [CENSORED]...
Just freezed at watching pics i have on players disc.
No way to get my facebook page loaded without freezing.
Must be defected player or some uncompatibility with hard disc.
« Reply #13 on: March 03, 2012, 12:11:34 pm »
There is a new issue which  all the internet is a having to deal with.  Certain internet services have decided they know best..and are circumventing the privacy settings in browsers to force the storage of cookies.   Cookie storage is disabled on the X2..and if circumvented...the X2 will crash or hang.
cilpet
« Reply #14 on: March 03, 2012, 12:19:56 pm »
As i noticed i am not the only one with same problems.
Happend again without hard disc again now ( Facebook freez).
Also noticed some other problems.
I was watching pics from my computer and when i set up the slide shows player reseted by itself.
Also found some funny bug on my player. When i want to jump to some part of mkv movie i can type just 1-9 number of 99 digit area ( minutes, seconds)
Is guess is still long way for me to be satisfied with this player more then i was the older one.
Pages: [1] 2   Go Up
