Author Topic: med500x2 keeps rebooting after skin  (Read 290 times)
TwieKers
« on: February 20, 2012, 10:48:22 am »
Hello,
Yesterday i decided to place a skin on my med500x2.
I used the "ClapperboardV2_canvas_skin" from here.
As i thought i wouldn't harm, i changed the BG_LAYER1.jpg file to a picture of my kids, using the same resolution.
As the file IMAGE_COMMON_LOGO.png also looked like the background i changed that one to to the same picture, also in png format, with the same resolution. I used photoshop cs5 to do all this.
Now i copied the whole map to the mede8er and i activated the skin.
Now it just keeps rebooting and rebooting over and over...
What should i do now?
Get the hard disk out of de mede8er and put it in my pc, to manually remove the map with the skin?
Or do sort of a reset bij putting the firmware on again?
Thanx for the help!  Smiley
« Reply #1 on: February 20, 2012, 11:01:55 am »
At what point is it rebooting...after the big med8er logo? That shouldn't be affected by any skin itneractions with the main code. So try an  emerrgency firmware install.
TwieKers
« Reply #2 on: February 20, 2012, 11:06:50 am »
Yes, it reboots after the black startup screen with the big mede8er logo.
I'll try a reinstall of the firmware.
Thank you.
edit: just reinstalled the firmware, everything works again now.  Smiley
I'll try an unmodified skin first now...  Wink
« Last Edit: February 20, 2012, 11:18:50 am by TwieKers » Logged
