the-osiris
« on: February 18, 2012, 02:12:56 pm » |
Hi guys, This new skin is modified from http://www.mede8erforum.com/index.php/topic,7822.0.htmlY2M Skin (Default skin from Y2M) Osiris_GreyBlack_Skin DOWNLOAD HERE :http://www.embedupload.com/?d=7PKLYHEYEAor http://dl.dropbox.com/u/49594197/Osiris_GreyBlack_Skin.rarLatest YAMJ2Mede8er : http://www.mede8erforum.com/index.php/topic,8000.0.htmlHOW TO INSTALL :1. Extract skin to YAMJ2Mede8er\Skins folder 2. Delete previous Jukebox, or make new jukebox folder (YAMJ Settings) 3. From YAMJ Settings, set skin to Osiris_GreyBlack_Skin 4. Generate new skin by Running YAMJ NOTE:In the attachment, aeon_title_cy.rar (additional font - install it by clicking and select install font) next time I will upload complete pack for this skin including Y2M-YAMJ-Mediainfo, I have slow internet connection at this time. _______________________________________________ Still need your feedback for improvement ! For those who wants to use smaller icon set ORIGINAL ICONS SMALLER ICONS Download smaller_icon_flags.rar from http://db.tt/kO5PODFk , extract it into YAMJ\\skins\Osiris_GreyBlack_Skin\html\pictures\flagsYou may also extract it into Jukebox\pictures\flags so you don't need to re-scan jukebox PM me is any links is dead
« Last Edit: March 23, 2012, 10:39:37 am by the-osiris »
Gogsysul
Offline
« Reply #1 on: February 20, 2012, 02:52:59 pm » |
Well, I took the plunge and formated my pc, went & upgraded to Y2M V2 and thought i'd give this skin a try... and boy am I so glad i did The pictures above dont really do it justice. Absolutely lovely job m8 (and i got my subs where i can see them now as well  ) So much nicer (and no disrespect intended) than the purple one you done, in my view
« Reply #2 on: February 20, 2012, 06:05:29 pm » |
the-osiris WOW!!!  What a great skin  Well done for this amazing work, Mede8er1
Mede8er1 The Greatest Show on Earth
marcepa
« Reply #3 on: February 20, 2012, 07:44:24 pm » |
@the-osiris, Il get an error in moviejukebox.log wen running y2m: Using properties file ./properties/moviejukebox-default.properties [18:39:33 - main ] Using properties file moviejukebox-Mede8er.properties [18:39:33 - main ] Using properties file ./skins/Osiris_GreyBlack_Skin/skin.properties [18:39:33 - main ] Failed loading file ./skins/Osiris_GreyBlack_Skin/skin.properties: Please check your configuration. The properties file should be in the classpath.
Any clue?
caka
« Reply #4 on: February 20, 2012, 07:51:56 pm » |
Great job! Nice refresh!
Maybe icons in footer are little bit to big, but that's only my opinion. In attachment you can see that if you have few subtitles or audio tracks, they are "dropping" out, so maybe a smaller font, or to move it from the start of the header.
« Last Edit: February 20, 2012, 08:44:19 pm by caka »
the-osiris
« Reply #5 on: February 22, 2012, 04:11:35 am » |
Any clue?  It seems that you have corrupted skin.properties file, try open it using notepad to confirm it. If problem persist, download it from attachment.
the-osiris
« Reply #6 on: February 22, 2012, 04:14:25 am » |
hi caka, thanks for your suggestion, about subs/audio at the header, you can edit the xml file in the jukebox to properly align. I will try to reconfigure the layout
marcepa
« Reply #7 on: February 22, 2012, 08:25:04 am » |
Sorry! It was my mistake.. I did not notice that the skin folder was nested twice with the same name. Solved! Thankyou! Good work!
Gogsysul
Offline
« Reply #8 on: March 04, 2012, 04:18:19 pm » |
the-osiris like i said in my previous post m8, great job on this skin.
Now while i was browsing for a film to watch last night I couldn't remember if I had watched a film or not in the about.jpg mode as image 1 below, and I was wondering if it would be possible to intergrate a pair of eyes from med8er to the skin to show up whether I have watched it or not as you can in other views??? I think that would be a nice addition if it's possible. Keep up the great work. Thanks M8 GS
Whooper
Offline
« Reply #9 on: March 05, 2012, 08:59:32 pm » |
I have two doubts with this skin, I really like that alias. Look at this picture below, pls click photo: Why I cut the picture below, and does not let appear in full all the "buttons" or "icons"? This cut appears to me equally in the Jukebox in 500x2. The 1st button / icon on the left to tell, this is not identified and appears "unknown video." This happens in all * about * the movies that I generated with YAMJ. Is there a way to change? In screenshots (already with the skin of Osiris - the third and fourth images) from the 1st post this icon appears differently. Some explanation for what happened?
« Last Edit: March 05, 2012, 11:10:18 pm by Whooper »
Sorry my English is not the best, I'm using the Google translator.
the-osiris
« Reply #10 on: March 05, 2012, 10:12:57 pm » |
hi Whooper, Your posted image is to small  1. Why there's cut-off pic in bottom icon : - You have long plot in your about.jpg (more than 6 lines), it will push those icons in the bottom page. - You may edit xml file (in jukebox folder) and truncate the plot, or set plugin.plot.maxlength (moviejukebox-Mede8er.properties) with lower values 2. Unknown video icon appears in all jukebox : - You don't state the movie source (Bluray, DVD, HD-DVD) in your movie filename, just put it on your movie filename (e.g : Garfield.2006.Bluray.mkv) cheers
the-osiris
« Reply #11 on: March 05, 2012, 10:58:55 pm » |
01). Embbeded Subtitle - Mediainfo - XML tag <subtitles> - External subs not supported - You have to edit from xml file if you have long list of subs (more than 2 subs), or it will spoil the layout  02). Embbeded Audio - Mediainfo - XML tag <audioCodec> 03). Studio - imdb - XML tag <company> - Requires same filename @Jukebox\pictures\studios 04). Release Year - imdb - XML tag <releaseDate> 05). Movie Duration - Mediainfo - XML tag <runtime> 06). Movie Rating - imdb - XML tag <rating> 07). Movie Casing/Box - filename - XML tag <videoSource> - Requires filename to state the source of the movie eg: Bluray, DVD, HD-DVD etc. - Affect also on Video Source Icon 08). Movie Title - imdb - XML tag <originalTitle> 09). Movie Plot - imdb - XML tag <plot> - plugin.plot.maxlength @moviejukebox-default.properties (YAMJ\properties) - imdb.plot @skin.properties(YAMJ\Skins\Osiris_GreyBlack_Skin) - You have to edit from xml file if plot is too long (if only imdb.plot=short has no affect) 10). Movie Certification - imdb - XML tag <certification> 11). Directed/Genre/Cast - imdb - XML tag <director> <genres><genre><cast><actor> 12). Icons - Mediainfo/filename - XML tag <videoCodec><audioCodec><audioChannels><container><videoOutput><fps><aspect> - For movie source icon, requires filename to state the source of the movie eg: Bluray, DVD, HD-DVD etc. NOTE:Use this nice tool to edit XML http://www.mede8erforum.com/index.php/topic,4991.0.html
Whooper
Offline
« Reply #12 on: March 08, 2012, 12:18:18 am » |
Hi, Osiris  I found that when I use your skin to generate the jukebox, the jukebox I totally crashes. However if you use another skin, the Y2M it no longer crashes. Do you have any solution for this? I must tell you that not modified any file that comes inside the RAR to your skin. Any idea how to prevent Y2M crash? Thank you, Hug! PIC --------------
the-osiris
« Reply #13 on: March 08, 2012, 07:10:54 am » |
Hi, Osiris  I found that when I use your skin to generate the jukebox, the jukebox I totally crashes. However if you use another skin, the Y2M it no longer crashes. Do you have any solution for this? I must tell you that not modified any file that comes inside the RAR to your skin. Any idea how to prevent Y2M crash? Thank you, Hug! From attached pic, as you can see, there's a different layout you got there, seems that you only changing skin (in Y2M settings) but not delete and re-scan jukebox. If you don't want to delete any jukeboxes, just created another one, then re-scan your collection using new skin.  cheers
Whooper
Offline
« Reply #14 on: March 09, 2012, 03:23:28 pm » |
Hello tested again with the pack of icons smaller and now it no longer crashes, but as some plots are a bit long, there are some cases where you and icons are left with a small cut. But nothing too serious.
Thank you for your support! Edit: In the series appear to me the icons in a strange way (not organized), check this pic:
check the red rectangle It is normal to the icons are messy? Give to have a more organized way?
« Last Edit: March 09, 2012, 04:17:22 pm by Whooper »
