Pages: 1 ... 3 4 [5]   Go Down
Author Topic: Feedback for - YAMJ To Mede8er V2.0.0 By Shizzl Yamj r2943 18 Feb2012  (Read 10014 times)
« Reply #60 on: May 24, 2012, 12:56:02 pm »
The length of the plot is limited in the jukebox XML view by size avail in the plot area.
And regarding the about.jpg moviesheet views it is limitied by the YamJ sheet used and the params from that sheet and the generic YamJ plotlength param or Thumbgen used sheet template.
urkens_jp
« Reply #61 on: May 27, 2012, 02:01:52 pm »
I can't get this version to work at all???
I did a clean install:
* Removed previous installation of Y2M
* Removed Jukebox
* Removed registry entries
* Installed the 64-bit version
* Updated MediaInfo to v5.57
* Reused the moviejukebox.properties from my previous installation having following entries:
     mjb.libraryRoot=H:/FILM/
     mjb.detailsDirName=Jukebox
     mjb.skin.dir=./skins/Y2M
     mjb.playerRootPath=H:/FILM/
     mjb.internet.plugin=com.moviejukebox.plugin.MovieMeterPlugin
     plugin.plot.maxlength=350
     thetvdb.language=nl
* As I am using W7-Ultimate x64 I'm running YAMJ_To_Mede8er_2.0.0 as administrator (otherwise accessright problems)
When I start Y2M I get a bunch of WARNINGs and ERRORS. In the log file following is shown:
WARN1: [13:24:41 - main    ] WARN  com.moviejukebox.tools.PropertiesUtil  - Warning (non-fatal): User properties file './skins/Y2M/skin-user.properties', not found.
=> indeed the file isn't present in the package
WARN2:[13:24:41 - main    ] WARN  com.moviejukebox.tools.PropertiesUtil  - Warning (non-fatal): User properties file './skins/Y2M\overlay.properties', not found.
ERROR1: When genarting the movie-details following exception occurs:
[13:30:45 - Thread-8] WARN  com.moviejukebox.writer.MovieJukeboxHTMLWriter  - javax.xml.transform.TransformerConfigurationException: Failed to compile stylesheet. 2 errors detected.
   at net.sf.saxon.PreparedStylesheet.prepare(PreparedStylesheet.java:199)
   at net.sf.saxon.TransformerFactoryImpl.newTemplates(TransformerFactoryImpl.java:132)
   at net.sf.saxon.TransformerFactoryImpl.newTransformer(TransformerFactoryImpl.java:87)
   at com.moviejukebox.writer.MovieJukeboxHTMLWriter.getTransformer(MovieJukeboxHTMLWriter.java:624)
   at com.moviejukebox.writer.MovieJukeboxHTMLWriter.generateMovieDetailsHTML(MovieJukeboxHTMLWriter.java:115)
   at com.moviejukebox.MovieJukebox$7.call(MovieJukebox.java:1506)
   at com.moviejukebox.MovieJukebox$7.call(MovieJukebox.java:1486)
   at java.util.concurrent.FutureTask$Sync.innerRun(Unknown Source)
   at java.util.concurrent.FutureTask.run(Unknown Source)
   at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Unknown Source)
   at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
   at java.lang.Thread.run(Unknown Source)
   at com.moviejukebox.tools.ThreadExecutor$ScheduledThread.run(ThreadExecutor.java:101)
=> anyone an idea which xsl-file gives this error?
ERROR2: When generating the HTML index pages following exception occurs:
[13:37:37 - Thread-9] WARN  com.moviejukebox.writer.MovieJukeboxHTMLWriter  - javax.xml.transform.TransformerConfigurationException: Failed to compile stylesheet. 1 error detected.
   at com.moviejukebox.writer.MovieJukeboxHTMLWriter.writeSingleIndexPage(MovieJukeboxHTMLWriter.java:586)
   at com.moviejukebox.writer.MovieJukeboxHTMLWriter.access$000(MovieJukeboxHTMLWriter.java:35)
   at com.moviejukebox.writer.MovieJukeboxHTMLWriter$1.call(MovieJukeboxHTMLWriter.java:540)
   at com.moviejukebox.writer.MovieJukeboxHTMLWriter$1.call(MovieJukeboxHTMLWriter.java:535)
=> again another stylesheet error?
quantumtraveler
« Reply #62 on: June 19, 2012, 07:13:24 pm »
Hi there, I'm running YAMJ To Mede8er V2.0.0 in 64 bit (on a 64 bit Win 7 machine). I can't get it to run  Huh
It keeps popping up a box "YAMJ settings are invalid" and/or "An application error occurred. If you have logging enabled please check the log file for details. Error details: Failed to compile stylesheet. 2 errors detected." It then gives me an option to: abort, retry, or ignore. Then when I select ignore or retry and make the changes, it crashes. What's up?
I've done all this: run the moviejukebox.bat file, deleted the YamjToMede8er registry key, deleted the contents of the jukebox. But it still crashes.
I've been in this forum all morning looking for the fix but can't find anything. Can you please help?
Edit: I have thoroughly read everywhere in this forum before posting, this was about the most helpful but there was no definitive fix for my issue: http://www.mede8erforum.com/index.php/topic,7836.msg49608.html#msg49608
I re-formatted my machine. Installed Java 32-bit and 64-bit (because Chrome only comes in 32-bit). Now it works perfectly. Weird stuff I know! But all's good and perfection again Smiley thanks for the amazing support guys.
For anyone else with this issue, I advise a re-format. I exhausted all other possibilities before resorting to this.
Nice1.
« Reply #63 on: June 19, 2012, 07:28:31 pm »
No not weird, some config issue on your PC, only question is which...
Sometimes looking for a solution can be more work the reinstalling windows and all other stuff.....
You made the right descision as the result is there...
quantumtraveler
« Reply #64 on: June 19, 2012, 07:29:43 pm »
Agreed, and thank you. Your guys support was incredible!! Big up for that Cheesy
« Reply #65 on: August 02, 2012, 05:03:18 pm »
Closed this feedback topic as there is a new version:
http://www.mede8erforum.com/index.php/topic,8829.0.html
Big thanks to Shizzle!!
Pages: 1 ... 3 4 [5]   Go Up
