The skin drop-down is blank and when I click it, nothing shows.
Then there is something wrong with the YamJ path.
Try this:
Rename the long folder you have YAMJ_To_Mede8er_2.0.0_Shizzl_yamj-2.6-SNAPSHOT-r2943_64bit_18Feb2012 to YAMJ.
Now start the program YamJToMede8er that is in the subfolder YAMJ_To_Mede8er_2.0.0_4Feb2012
For the paths you use:
Path to YamJ: C:\Portable Files\YAMJ
Movie folder to scan: point this to a root folder with movie subfolders in it.
Jukebox location: Can be any path, this will only create a buffer of scraped info that will be used to create the scraping pictures when you press on Copy to Mede8er after the Run YamJ filled this folder.
When path settings are correct of Path to YamJ, you will be able to select a skin in the YamJ Skin selection field.
If it still stays blank then:
- you have not downloaded the complete package
- or your path setting is still wrong, it should point to the folder where e.g. the MovieJukebox.bat file is in.
- or you dont have a skins subfolder in your YAMJ folder (which should be there as it is included in the full package)
