When having problems to connect to your internal mede8er disk over the network from a pc:
Try Mede8er HDD Connector Tool:
EDIT: this is now combined in the Mede8er Share manager located here:
http://www.mede8erforum.com/index.php/topic,7970.0.htmlFirst be sure you have enabled NAS to on in setup (and have an internal HDD in your Mede8er)
1] Fill in the right hostname (if you changed the default in mede8er setup)
2] Press on search
3] Select the Mede8er found
4] Press on Mount
