Author Topic: [TIP] Easy Connect to Win Vista32 shares using guest account (Rev 2.0 or higher)  (Read 1007 times)
« on: January 03, 2010, 01:09:31 am »
This only applies to firmware 2.0 or higher to access your PC from your mede8er
First step: enable file sharing on Win Vista 32:
1. Control panel
2. Network and Internet
3. Network and Sharing Center
4. Under Sharing and Discovery:
                 a.   Turn on Network discovery
                 b.   Turn on file sharing
Second step: enable the guest account
1. Control panel
2. User Accounts
3. Manage Another Account
4. Click on the Guest Account icon
5. Click on enable guest account
Third step:  Share desired folders on your PC for the mede8er:
1. Start Windows Explorer (Not confuse with Internet Explorer)
2. Goto the folder you want to share on one of your local discs
3. Click with right mouse on the folder to share
4. Select Share
5. On pull down bar select Guest and click on add button
6. Click on Share button on the button.
Last step: Get access from your mede8er:
1. Goto the Network menu
2. Select WORKGROUP and select the Win Vista PC with ok. (or add PC in Shortcut menu as described here if you don't see workgroup and pc: http://www.mede8erforum.com/index.php?topic=47.0)
3. For user fill in: guest leave password blank and select OK or OK save to shortcut
To access the mede8er from your PC:
- Be sure that you have switched NAS to ON in the Mede8er setup
- On your PC open the file explorer (so not the internet explorer)
- Click on the network icon and your Mede8er will show up. Click on it to browse the content of the internal disk if you have one installed
- If you don't see it, try to type \\mede8er on the input line on the top (or if you gave it another hostname type the hostname in stead)
« Last Edit: January 03, 2010, 12:25:07 pm by Maasbommel » Logged
Panasonic SA-PTX5
ProgHead
Jr. Member
WWW
« Reply #1 on: January 12, 2010, 05:41:02 pm »
Does this work only with Vista 32bit?
i have a Vista 64bit, should I try or better not?
ph
Product & firmware version: Mede8er MED500X f/w v3.0.2
GUI Language Setting: Italian
Audio setting: HDMI 2ch downmix / Night mode COMFORT
Video: HDMI output > TV
Video setting: 720p 60Hz,16:9
Media Source: Internal HDD
Internal HDD: WD GREEN 1TB, formatted with Mede8er setup in f/w 1.2.2a
« Reply #2 on: January 12, 2010, 08:17:06 pm »
Have not tested on Win Vista 64, so not sure if that will work. Have no Vista 64 PC available to test this.
I would suggest to just give it a try and give your feedback.
Panasonic SA-PTX5
