OK the artwork ect is working, however I now have a much bigger issue.
When I try and open the HDD in Thumbnail mode the display disappears and I have to restart the unit each time.
Firmware is 1.6
Setup
200GB Seagate drive (ST9200420AS) formatted with Mede8er
3 folders (Movies, Photo, TV)
Problem
While navigating in Thumbnail modeOpen Media Library
Devices > HDD shows up OK ... Enter
HDD > C: shows up OK ... Enter ... the three folders (Movies, TV and Photo) show up to a second then boom, the display goes dead (it sounds as though the HDD shuts down for a second and restarts) Only way to recover is restart the unit.
While navigating in List modeOpen Media Library
Movies, Photo, TV folders show up and display does not disappear
Can go into Movies and access media OK
Also at this point I can change the Movie folder back to Thumbnail view and browse them by cover.
I can also get from showing the C drive to opening it in Preview mode.
So basically Thumbnail mode is causing the unit to bomb out when opening the C drive.
Second issue
I loaded 76 pictures in the Photo folder and everytime I try and load them the display also disappears and I have to restart the unit.
EDIT: Possibly found the causeI tried loading the exact same files with my external USB HDD and the unit crashes while opening the drive at the same spot in Thumbnail mode.
However ... after deleting the "Photo" folder the unit no longer crashes!
So now the question is why is the Photo folder causing the unit to crash?
Like I said it has 76 pictures with a resolution of 720x480 each and the files are named Wedding Pictures (1) - Wedding Pictures (76)
Will try renaming the files (no spaces) later and retest, but I've washed enough of my Sunday for now
