Pages: 1 [2] 3 4 ... 8   Go Down
Author Topic: Music Jukebox. Get Ready! (FAQ with Videos)  (Read 7229 times)
« Reply #15 on: February 09, 2012, 05:03:00 pm »
Bump...new information in FAQ on size of folder.jpg for use with new Music Jukebox screensaver.
« Last Edit: February 09, 2012, 06:36:44 pm by jer1956 » Logged
« Reply #16 on: February 11, 2012, 11:44:41 am »
Bump..new information in FAQ on improved scanning speed.
« Last Edit: February 11, 2012, 11:50:14 am by jer1956 » Logged
« Reply #17 on: February 12, 2012, 01:09:33 pm »
Bump..new information in FAQ for tagging compilations.
« Reply #18 on: February 17, 2012, 01:22:13 pm »
Bump..new information in FAQ on external playlists.
rwielinga
X2 Skin Designer
« Reply #19 on: February 17, 2012, 02:17:17 pm »
Eagerly watching this topic for a release. Keep up the good work, I look forward to using this.
« Reply #20 on: February 17, 2012, 08:54:17 pm »
Someone asked for more information after the Publicity Announcement..and you can see how things change as development progresses by the changes to the information we have managed to release.
rwielinga
X2 Skin Designer
« Reply #21 on: February 17, 2012, 10:11:10 pm »
Thnks for the updates, keep it up! Smiley
« Reply #22 on: February 17, 2012, 10:27:29 pm »
I can only speak  for myself..but if you have been changing things to match what's been posted..you will install the software and go WOW.
If you  havn't..it's going take a lot of work to catch up.
rwielinga
X2 Skin Designer
« Reply #23 on: February 17, 2012, 10:36:04 pm »
Ha, I better start catching up then! Cheesy
« Reply #24 on: February 18, 2012, 12:26:45 pm »
Bump. New Promo video added to main post.
« Reply #25 on: February 28, 2012, 05:34:43 pm »
Bump..New information in FAQ on supporting m4a.
bretter
« Reply #26 on: February 08, 2013, 09:36:54 am »
 Hi JER1956,
how're you.
In your first post you stated:
"All supported audio codecs using Tags can be used.
If you have a mix of MP3 and other formats...Tagscanner is used to scan everything."
On FLAC files, you have an example:
http://www.mede8er.org/artwork/temp/Mede8er_music_jukebox_flac_tags.mp4
So tagging FLACS should work.
Actually, reading this post decide me to buy a 1000X3D ....  Grin
... but ...
First: when adding tagged MP3 files to the Med (generated by Tagscanner), the music jukebox works fine.
Second: when adding tagged FLAC files to the Med, the music jukebox doesn't work at all ...
It can only play the files and show the coverart (folder.jpg) but I lose all the jukebox functionality (playlist, searching).
I undestand the TAG EDITOr, MUSIC RENMER, LIST MAKER but whatever I try within Tagscanner, it keeps adding VORBIS tags to mij FLAC files. Even when I save to ID3, APE or AUTO.
And the 1000X3D can only read ID3 tags. Embarrassed
So, when scanning the (just added) FAVOURITES map (I named it MUSIC, which keeps the FLAc files),
the Med1000X3D returns: "No ID3 Tag information found".
I've trying for over a week now .... the forum and Tagscanner user manual isn't helping much either, it's not specific enough.
QUESTION: how can I generate tags for FLAC-files within TAGSCANNER so that the Med1000X3D can read them ?
Thanking you in advance,
Player: 1000X3D
FW: v1.05
HDD: WD Blue 750 GB (WD7500BPVT), http://www.wdc.com/en/products/products.aspx?id=800
« Reply #27 on: February 08, 2013, 11:19:50 am »
Please post your tagscanner xml.  You are scanning the folder in which is the XML is found?
bretter
« Reply #28 on: February 08, 2013, 03:19:28 pm »
Hi Jer,
 ... thanks for your fast response.  Grin
This is the map-structure that I want to make on the Med:
E:\Music\CSNY
E:\Music\Beatles
E:\Music\Beatles
E:\Music\Eagles
E:\Music\Tracklist.XML
In wich E: is the internal HDD on the Med (according to my PC when connected with the blue cable).
Music is the Root-folder.
CSNY is Artist-folder.
The Album-folder contains the tracks (01-carry on, 02-teach your children, 03-almost cut my hair, etc...)
The tracks are tagged with Tagscanner (manual via TAG EDITOR) and renamed to: %track%-%title%.
So the tracklist.xml is in the music folder, as it should be according to the manual.
Within the Med:
First I add the Music-folder to my Favourites, this works fine.
Then I go to the Favourites, and scan the (just made) Music-folder; followed by the message "No ID3 Tag information found" .  Embarrassed
So the Med cannot build a database (music.db) and I can only play the individual songs.
EXAMPLE: this is the tracklist.xml of the above CSNY album:
<?xml version="1.0" encoding="utf-8" ?>
- <filelist>
  <root />
  <totalfiles>10</totalfiles>
  <totalsize>201,72 MB</totalsize>
  <totallength>00:36:21</totallength>
  <date>8-2-2013 14:03:54</date>
  <generator>TagScanner 5.1.630 Mede8er X2 Firmware 2.0.7, V1.0.2u, modified 25-Apr-2012 by Unreal</generator>
- <artist>
  <name>Csny</name>
- <album>
  <album>Csny - Deja Vu</album>
  <genre>Pop</genre>
  <year>1970</year>
  <path>CSNY/</path>
- <track>
  <title>Carry On</title>
  <filename>01-Carry On.flac</filename>
  </track>
- <track>
  <title>Teach Your Children</title>
  <filename>02-Teach Your Children.flac</filename>
  </track>
- <track>
  <title>Almost Cut My Hair</title>
  <filename>03-Almost Cut My Hair.flac</filename>
  </track>
- <track>
  <title>Helpless</title>
  <filename>04-Helpless.flac</filename>
  </track>
- <track>
  <title>Woodstock</title>
  <filename>04-Woodstock.flac</filename>
  </track>
- <track>
  <title>Deja Vu</title>
  <filename>06-Deja Vu.flac</filename>
  </track>
- <track>
  <title>Our House</title>
  <filename>07-Our House.flac</filename>
  </track>
- <track>
  <title>Four Plus Twenty</title>
  <filename>08-Four Plus Twenty.flac</filename>
  </track>
- <track>
  <title>Country Girl</title>
  <filename>09-Country Girl.flac</filename>
  </track>
- <track>
  <title>Everybody I Love You</title>
  <filename>10-Everybody I Love You.flac</filename>
  </track>
  </album>
  </artist>
  </filelist>
Something wrong .... I don't see it ... Huh
« Reply #29 on: February 08, 2013, 03:30:44 pm »
1) start with a standard script as found here:-
http://www.mede8er.com/mede8er_music_jukebox_user_guide_x2_x3.html
2)you structure would work on the internal drive,,but on remote stores you must use share/music/music folders.
So  you need an extra parent folder..and that is what is shared.  You then link to  the Music child folder.
Pages: 1 [2] 3 4 ... 8   Go Up
