Author Topic: Music cover art  (Read 21412 times)
Offline diapason
Music cover art
« on: January 13, 2012, 05:37:00 PM »
Hi ,
What is the best site to download audio covgers from?
What prg. does one use to scape above mentioned covers?
Diapason
Diapason
1 * Mede8er 1000X3D, FW 301
2 * Mede8er 500x2,FW 210,
1 * 500x, Fw 405,
Lan to pc network 1 *xp, 1 * Win 7.
HDMI to Cambridge Audio Azur 651R
Hdmi to Samsung PS50C550
Cambridge Azur 650BD Player
Offline AdrianH
Re: Music cover art
« Reply #1 on: January 17, 2012, 07:55:37 PM »
For batch processing I use MusicBrainz Picard from http://musicbrainz.org/doc/MusicBrainz_Picard.  It is configurable to update (or not) all the tags, update (or not) the album art in the tag and/or into a file.
For individual processing and tagging, I normally use MP3Tag from http://www.mp3tag.de/en/index.html.  Also does tagging manually or from an external source like amazon, and can also update album art only if you want.
Re: Music cover art
« Reply #2 on: January 17, 2012, 09:21:30 PM »
X2 users should get used to using this:-
http://www.xdlab.ru/en/index.htm
It's at the heart of generating information for the new Music Jukebox. It needs a script for that...which won't be released until it has been finalised.
« Last Edit: January 17, 2012, 09:28:09 PM by jer1956 »
Offline AdrianH
Re: Music cover art
« Reply #3 on: January 18, 2012, 07:30:48 PM »
Is this the program that will be used to generate the meta-info that the X2s will use to build the music jukebox database?  Will I still be able to use my preferred programs for tagging my mp3s, namely MP3Tag and MusicBrainz Picard and then just use TagScanner for the Jukebox generation?
Re: Re: Re: Music cover art
« Reply #4 on: January 18, 2012, 07:33:28 PM »
Correct. You still can edit mp3 tags with the program you like.
Offline CDM040971
Re: Music cover art
« Reply #5 on: April 09, 2012, 03:51:23 AM »
Hi Everyone,
TAGScanner is the only option to provide Music file fanart for x2? I understand we need a script and that it will be delivered when development is done. I'm still working through my movie files so have some time. Just wondering when we can expect the script.
Thank you :)
Chris
Re: Music cover art
« Reply #6 on: April 09, 2012, 08:28:47 AM »
Hi Chris,
The Tagscan script you are talking about is included in the Music Jukebox User Guide.
Suggest to start reading here: http://www.mede8er.com/mede8er_music_jukebox_user_guide.html
Offline PCoetzee24
Re: Music cover art
« Reply #7 on: December 03, 2013, 05:35:15 AM »
The script supplied for TagScanner seems to only create the Tracklist file that I need for building the Jukebox.
I'm looking for a way to automatically download and update all my music folders with a fanart.jpg image like the ones from fanart.tv. Does TagScanner 5.1 support downloading fanart or only cover images?
Offline jasfdufd
    • black magic specialist
Re: Music cover art
« Reply #8 on: December 13, 2013, 03:09:14 AM »
you can find from google easily
Offline PCoetzee24
Re: Music cover art
« Reply #9 on: December 23, 2013, 11:34:55 AM »
I have trolled the internet and did not find anything useful. Did you?
Is there anything that is actually useful you would like to share?
Offline momo2013
Re: Music cover art
« Reply #10 on: December 29, 2013, 10:13:14 AM »
Hi.
Personnaly, i'm using Album Art Downloader that you can find:
http://sourceforge.net/apps/mediawiki/album-art/index.php?title=Main_Page
Individual or batch process covers simply.
Offline Guttend
Re: Music cover art
« Reply #11 on: January 20, 2014, 07:56:15 AM »
Album Art downloader works fine.
nenito2k
  • Guest
Re: Music cover art
« Reply #12 on: November 21, 2014, 12:21:04 PM »
old thread i know...but i Really dislike tagsanner....is there anyway to make musicbrainz compatible with the MED X3 ??? it works on pc...but since the software does not create any xml file (as far as i know...)the MED can't see it !!!
any other olternatives ?
Re: Music cover art
« Reply #13 on: November 21, 2014, 12:25:52 PM »
Until finding Tagscanner, Music Jukebox was stuck on the back burner.    So its not a question of Tagscanner being the only software adapted to  support the Music Jukebox,  the Music Jukebox was  designed around what Tagscanner could do.
The underlying problem is realtek only support Mp3.  If you have a fully tagged mp3 collection  you  don't need tagscanner.  Scan  will  create the music jukebox direcly from the mp3 tags using the realtek extract mp3 tags SDK function.
