Author Topic: Default Thumbgen Template Enhancement  (Read 1511 times)
AdrianH
B8a Tester - X2
« on: January 08, 2012, 10:14:52 pm »
Hi All,
I have updated the "Default Thumbgen Template" movie sheet with the following changes:
* Added Certification graphic (uses US ratings from IMDB)
* Added MPAA text (from IMDB)
* Remove sub-titles and replaced with filename.
To use, replace the "Template.xml" file in the "_Default ThumbGen Template_" folder with the attached one, and unzip the certification graphics into a sub folder called "certifications" under the "_Default ThumbGen Template_" folder.  Also, your collector must get info from IMDB.
Also make sure that in Thumbgen options, you choose United States as the "Get Certification for:" in the IMDb Options.
Enjoy!
