Pages: 1 2 [3] 4   Go Down
Author Topic: [TIP] Mede8er 400X/500X Beginners Guide  (Read 80989 times)
« Reply #30 on: September 17, 2010, 03:03:00 pm »
Added in the guide:
o Howto fix your mkv NEW
o Howto check if you have a Med500X DD or DD+ unit NEW
(see the first post in this topic)
In the FAQ section.
fuki
« Reply #31 on: October 02, 2010, 11:00:11 pm »
hallo to all!!
My Mede8er with 2TB HDD at home from yesterday...
Setup finished, and now copyng files over the network...
Everything works fine...
sorry for my bad english, and THX for the perfect beginners guide....
regards, fuki
« Reply #32 on: October 02, 2010, 11:02:05 pm »
Thanks fuki and welcome on this forum.
Priit
« Reply #33 on: October 20, 2010, 04:55:07 am »
Hi, I´m v. glad I found such thread about my forthcoming device after placing the order,
will hopefully receive it in next few days.
This guide will be lot of help, sure,
thanks for this excellent content!
And thanks for the style! Great concept!  Cool
Wish You the best with forthcoming firmware release!
« Reply #34 on: October 20, 2010, 08:09:42 am »
Thanks! This kind of comments keep me going....,
Jap
« Reply #35 on: November 14, 2010, 03:13:14 pm »
Nice guide! Helped me a lot!
Just another question.. Is it possible to listen music without having the tv on? I have my mede8er with 1,5 TB harddisk connected to a onkyo ht-r538 a/v receiver and then connected to my television Philips 42 PFL5405 but when i shut it off the whole player quits playing.
I installed the v4beta firmware.
Tnx
Mede8er MED500X-1500 + 1.5TB HDD
Connected with a Onkyo HT-R538 A/V Receiver
On a Philips 42 PFL5405 Full HD screen
« Reply #36 on: November 14, 2010, 04:33:08 pm »
It should be possible but only problem is that you don;t see the tracks to select them.
But when its playing and you only shut off the TV, normally you still should get sound over your AMP.
Jap
« Reply #37 on: November 17, 2010, 06:06:07 pm »
Is it possible to play whole maps at once? I have sorted my music by [map]artist - [map]album - tracks. But is it possible to play all the albums of one artist? That i choose the artist map and that it will play all the tracks in the maps of that artist?
Tnx
« Reply #38 on: November 17, 2010, 08:44:33 pm »
No, currently not possible, you have create playlists.
Use search on the forum on playlist or play list.
You will find several topics on this.
bj
« Reply #39 on: December 02, 2010, 06:16:53 pm »
Thankyou for your work in compiling a beginners guide--it is much appreciated
IceDem0n
« Reply #40 on: February 16, 2011, 12:24:07 am »
video wall how dose that work it came in last update and i can access it
« Reply #41 on: February 16, 2011, 12:36:00 am »
This is a tip section and only for placing tips...
Please make a post in a proper section.
deedas
« Reply #42 on: April 27, 2011, 12:07:29 pm »
Hi Maasbommel
Where do I find info on how to use the Background music facility that can be setup as "folder or playlist"
« Reply #43 on: April 27, 2011, 07:04:32 pm »
Do you mean this:
http://www.mede8erforum.com/index.php/topic,717.0.html
jasgot
« Reply #44 on: May 04, 2011, 12:35:32 am »
Great topic!
While reading, and reading, and reading! I came across an invalid link, thought you might like to know.  It is a link I am eager to get to also....
Under General Use:
Mede8er supported video codecs and audio codecs
Pages: 1 2 [3] 4   Go Up
