Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
Username :
Password :
April 19, 2024, 08:48:04 PM
News:
Don't have a Mede8er? Buy yours now:
www.mede8ershop.co.za
Home
Help
Search
Login
Register
Mede8er Forum
Mede8er Products
MED500X2/MED400X2/MED400X2S/MED450X2/MED450X2S
Technical Issues
MED500X2 - Can't save config
« previous
next »
Pages: [
1
Go Down
Author
Topic: MED500X2 - Can't save config (Read 2167 times)
AdrianH
B8a Tester - X2
Helpful Contribution Status: +1/-0
on:
December 30, 2011, 09:02:21 PM »
Hi
I tried to "Save Config" today but after a few seconds it comes up with "Failed!" Running firmware 2.0.3 with an internal 2TB hard drive. Any ideas?
Regards
M8er Addict
Helpful Contribution Status: +51/-8
Re: MED500X2 - Can't save config
Reply #1 on:
December 30, 2011, 11:12:25 PM »
Did you put an usb stick in your mede8er usb port?
It only saves the config to a config file on an usb stick.
Read the
Mede8er 400X/500X Beginners Guide
or
Mede8er 500X2/400X2/450X2 Beginners Guide
Also check the
Couto X3D Newbies Guide
first.
AdrianH
B8a Tester - X2
Reply #2 on:
December 31, 2011, 08:56:10 AM »
Ah yes, that did the trick.
Pages: [
1
Go Up
« previous
next »
Mede8er Forum
Mede8er Products
Technical Issues
