Author Topic: [TIP] Misc setup menu description  (Read 1625 times)
« on: December 31, 2009, 12:42:29 pm »
Misc setup menu description (firmware version 2.0.2)
Resume Play (on / off)
When on the Mede8er "remembers" where you stopped playing your movie.
Next time you start the same movie again, it will ask you if you want to resume on the same point or not.
Slide Show Timing (off / 2s / 5s / 10s / 30s / 1min / 2min)
To set the time a picture remains on screen when running a slide show of pictures in a folder or playlist.
Transition Effect
Transistion effect to be used when playing a slide show of pictures.
Ken Burns (on / off)
Special effect when showing a picture or picture slideshow.
Youtube example
Wikipedia link
Seamless Playback (on / off)
Set to on when streaming/playing TS .vob files
Background Music (Off / Folder / Playlist)
Preference for playing music during a slideshow of pictures.
Folder: place some music files in the same folder as the pictures your are playing. Music files will play in the background
Playlist: when starting a slideshow music files that are in your music playlist will be played
Howto make a playlist
Screen Saver (off / 90s / 180s / 5min)
Screensaver mode to protect your TV for burn-in effects.
Time set to the period of inactivity when the screensaver gets activated.
Screensaver will not start when playing a movie or running a picture slide show.
When playing music the screensaver will start after the configured period and will display the name or ID-Tag of the current playing song when available.
Movie Preview (off / on)
Enables preview mode of movie files.
When browsing folders with large amounts of movies in it on local harddisk or over the network, disabling this mode will speed up browsing through your folders.
Subtitle on-off
Default subtitle mode on or off.
« Last Edit: January 13, 2010, 09:25:29 am by Insomniac » Logged
Panasonic SA-PTX5
zdravkos
« Reply #1 on: January 04, 2010, 01:41:28 pm »
Is it possible to have movie preview on, but without movie sound?
« Reply #2 on: January 04, 2010, 01:56:18 pm »
No there is no option for it in setup. With preview on, you will hear the sound of the file previewing.
Of course you can use the "mute" feature on your Mede8er remote, or just switch off movie preview.
Panasonic SA-PTX5
« Reply #3 on: June 15, 2010, 08:12:50 pm »
Locked this topic because it is not for support questions.
Please put support questions in the Technical Support section of the board.
Panasonic SA-PTX5
