Author Topic: PC Connect  (Read 751 times)
RMare
« on: December 23, 2011, 10:10:18 am »
Installed FW 4.0.5 can not get my pc to connect to MED500X, PC is on OS win 7 Ultimate. Did the same on previous Firmware.
« Reply #1 on: December 23, 2011, 11:43:43 am »
You posted in the wrong section - will move your post to the 500X section. This is the 200x/300x/250x section.
« Reply #2 on: December 23, 2011, 12:01:03 pm »
..and this is the x2 section..... Cheesy
This post is going to get dizzy.
« Reply #3 on: December 23, 2011, 12:05:21 pm »
If you had problems with 4.0.4...then those issues have not gone away.  We did have some who had working v3 networks...and then they had problems with the network fixes added to V4.0.4. Ironically those fixes meant those who had v3 networking issues no longer had them.
This Tip evolved duiring this process:-
« Reply #4 on: December 23, 2011, 01:01:26 pm »
That is what happens when a post only has one line withouth the needed details....
Totally unclear if we are talking about network or usb connection...
Suggest the poster to read the technical support guidelines first to have an idea what details are needed:
http://www.mede8erforum.com/index.php/topic,14.msg19.html#msg19
