Author Topic: MAC QUESTION: Any way to generate xml files like Y2M does on a mac?  (Read 823 times)
WeeDz
« on: December 18, 2011, 09:25:23 pm »
I've been playing around a bit with my new MED500X2. To create my about.jpg and folder.jpg I've used DuneX, which works very well for that.
Now to get the full potential out of the media library i'd like to get the metadata display working. This requires XML files which can be generated using Y2M. Is there any way to do this on a Mac? DuneX doesn't seen to do this, or am I overlooking something? It creates a database though, but no XML files.
Any help is much appreciated.  Smiley
Regards,
asaweli
« Reply #1 on: January 23, 2012, 01:12:28 am »
Dear WeeDz,
did you figure this out yet? I am also stuck with the same question. If not Hopefully i just bumped this post and we might get a reply from someone else...
thnx
« Reply #2 on: January 23, 2012, 06:00:57 pm »
I have seen this solution mentioned in the past:
http://www.mede8erforum.com/index.php/topic,6942.msg44646.html#msg44646
micasha
« Reply #3 on: February 05, 2012, 11:46:02 pm »
maybe this will help
http://inhousedesignsinc.com/software/TOMY/TOMY.html
macuser
B8a Tester - 1000X3D
« Reply #4 on: February 06, 2012, 10:02:39 pm »
Tomy is not compatible with Mede8er's xml files.Until now there is not a native mac application to make friendly xml files for Mede8ers media players.
There is something made for me,a friend for South Africa.Can convert Tomy's xml files to be friendly with mede8er.It is in java,but after convert you must ad manually the new xml to your movies folder,one to one.If anyone interesting i can upload this utility to rapidshare.
Optoma HD80,Sharp LC-52DH65E, Mede8er MED1000X3D 3 TB WD green HDD -> with ethernet cat 6 to Time Capsule 3 TB, Marantz NR 1602,Apple TV2,Dune HD Duo, LG HR550, Pace DS-831,Roister HT-3300
Sharp LC-42SB55E,  Mede8er MED400X2,Yamaha YSP 800,Samsung BD C5900,Dune Lite 53D,Apple TV3
MacBook Pro, MacBook & MacPro, latest Lion OS
WD MyBookWorld II 2TB NAS Server
0xJay
« Reply #5 on: January 25, 2013, 03:03:38 pm »
Wow, is this still the only solution?
6TB RAID0 FW800
OS X 10.8.2
NFS 16k rsize
(CAT5e) Actiontec MI424WR
Mede8er 600X3D
(HDMI 1.4a) Onkyo TX-SR508
(HDMI 1.4a) Samsung UN55ES8000
Administr8or
« Reply #6 on: January 25, 2013, 03:28:03 pm »
http://www.mede8erforum.com/index.php/board,105.0.html
