Home build NAS
Used Hardware:HP Proliant Microserver 40L
2x 4gb KTH-PL313E/4G 4GB 1333MHz ECC Module Kingston
4x WD20EARX-00PASB0 2TB green Western Digital
Sandisk 8GB U3 Titanium USB stick
Samsung USB DVD writer SE-208
Network router used:Netgear WNDR3700
Used Software:OpenMediaVault free nas operating system build on Debian linux distribution
http://www.openmediavault.orgVersion: 0.2.5.7
Kernel Linux 2.6.32-5 amd64
Used resource for installation:OpenMediaVault WikiInstalled the plugin manager:http://omv-plugins.org/Used NAS disk configuration: Raid Level : raid5
Array Size : 5860538880 (5589.05 GiB 6001.19 GB)
Used Dev Size : 1953512960 (1863.02 GiB 2000.40 GB)
Raid Devices : 4
Total Devices : 4
Raid5 set formatted as XFS
All disks have set Write Cache to on.
On the SMB/CIFS filesystem have set Use Sendfile to on.
Speed test done with:Nas Performance Tester 1.3PC: Intel Quadcore Q6600 Win 7 64bit Ultimate 6GB memory
Running a 200MB file write on drive Z: 5 times...
Iteration 1: 113,76 MB/sec
Iteration 2: 107,23 MB/sec
Iteration 3: 110,31 MB/sec
Iteration 4: 103,41 MB/sec
Iteration 5: 114,87 MB/sec
Average (W): 109,92 MB/sec
Achievement unlocked: 100MB+/sec write speed!
Running a 200MB file read on drive Z: 5 times...
Iteration 1: 67,45 MB/sec
Iteration 2: 84,21 MB/sec
Iteration 3: 80,25 MB/sec
Iteration 4: 76,86 MB/sec
Iteration 5: 75,93 MB/sec
Average (R): 76,94 MB/sec
Running a 400MB file write on drive Z: 5 times...
Iteration 1: 103,17 MB/sec
Iteration 2: 102,56 MB/sec
Iteration 3: 97,99 MB/sec
Iteration 4: 101,11 MB/sec
Iteration 5: 101 MB/sec
Average (W): 101,16 MB/sec
Running a 400MB file read on drive Z: 5 times...
Iteration 1: 83,26 MB/sec
Iteration 2: 84,71 MB/sec
Iteration 3: 65,12 MB/sec
Iteration 4: 70,23 MB/sec
Iteration 5: 76,46 MB/sec
Average (R): 75,96 MB/sec
Read performance is less then write because of the used software RAID5.
Using JBOD configuration (4x separate disk), gives both read and write above 100MB/s
OpenMediaVault Forum for tips, tricks and specific questions:http://sourceforge.net/apps/phpbb/openmediavault/index.phpUsing Med500X / 400X2 / 500X2 to stream from it.
Setup als follow:
Using the My_Shortcuts method as shown in this demo
http://www.mede8er.com/Mede8er_X2_Add_Shortcut.htmlAlso using NFS streaming from 400X2 and 500X2 without issues.
