Author Topic: HarmonyŽ One Advanced Universal Remote work on the MED500X2  (Read 953 times)
ufoblue84
« on: December 10, 2011, 02:19:16 am »
I heard logitech added the software for the HarmonyŽ One Advanced Universal Remote to work on the MED500x but have they bought an new update for the MED500X2??
Please respond. Thanks
« Last Edit: December 10, 2011, 02:42:40 am by ufoblue84 » Logged
mariusven
« Reply #1 on: December 10, 2011, 08:39:24 am »
I have a Harmony 900. I loaded the MEDE8ER option under COMPUTER --> MEDIA CENTRE PC and typed model MED500X2.  That provides me with the new commands such as EDIT and VIEW. Works fine.
Med500X and Med500X2, latest firmware, internal 1.5TB Seagate, ethernet 1000BaseT
Sony 46" full HD, Yamaha RXV-3800,
Cambridge Audio DAC magic,
B&W 703 speakers
ufoblue84
« Reply #2 on: December 10, 2011, 09:00:46 am »
Hi thanks for your reply Smiley So all the functions work on your harmony remote control that would work on the orignal remote control of the MED500X2?
liberatrix
X2 Skin Designer
« Reply #3 on: December 10, 2011, 10:33:45 am »
Yep, everything works fine with the Logitech Harmony One, and using the BIG play/pause button is so cool  Cool
xxquartzxx
« Reply #4 on: December 10, 2011, 11:09:44 am »
All working fine on mine as well ...  Grin
Product: Mede8er MED500X2 f/w v2
Audio: HDMI: Onkyo Tx-sr-608
Audio:setting: HDMI Passthrough
Video: HDMI:output:Samsung 50" Plasma
Video setting:1080p 50Hz,24Hz ON,16:9
Media Source: Wired Network > Windows 7 Professional SMB shares
MED500x2:Hard Drive: 2TB Green Western Digital
External HDD: 1TB Western Digital
« Reply #5 on: December 10, 2011, 11:35:15 am »
Anyone getting double moves using the cursor controls? This has been reported by others...after they used learn mode.
liberatrix
X2 Skin Designer
« Reply #6 on: December 10, 2011, 01:12:37 pm »
No, i use standard button settings from Logitech for Med500X2. I did not have to use the learn mode.
Maybe 'they' have not used the correct settings. I did program the remote f.i. pressing the GUIDE button and you go to the FAVOURITES screen (same as pressing BLUE button on original Med remote)
« Reply #7 on: December 10, 2011, 01:22:11 pm »
Perhaps some people have older versions with no specific X2 profile for their model?  It is useful to know that there is a solution for those who want to use a universal  remote...even if  it means upgrading their remote!
liberatrix
X2 Skin Designer
« Reply #8 on: December 10, 2011, 01:53:29 pm »
saskir
B8a Tester - X2
Senior Member
« Reply #9 on: December 13, 2011, 01:46:06 pm »
Hmmm, let's say I have no double jumps since the new Firmware. Before I had the problem that certain commands get send "too often" or twice (dunno the correct word for this, simply if you pressed the button for "right" it could be that it was going two positions in this direction instead of one). Happened also with the normal remote, so it was not an error in the Logitech one.
