Author Topic: MED250X Firmware Update V1.5 -- 1Dec2011  (Read 1490 times)
Administr8or
Online Online
« on: December 01, 2011, 09:42:10 am »
New update for MED250X
Changelog V1.5
1) Fixed Alpha sorting on USB fat32 Drives
2) Changed screensaver image
3) Selection of Font A or B in Setup Menu
4) Fixed aac sound in MOV file
MED250X INTERNATIONAL VERSION
http://www.mede8er.org/beta/Firmware_Final/MED250X/MED250X_V1.5_1Dec.rar
MED250X THAI VERSION
http://www.mede8er.org/beta/Firmware_Final/MED250X/MED250X_V1.5_Thai_1Dec.rar
Update Procedure
UnZIP or UnRAR the file and you will find one file named install.img. Copy this file to the root directory of a Flash Drive. Plug the flash drive into the Mede8er. Disconnect the power jack at the rear of the Mede8er then plug it back in - Now press the on/off button on the Mede8er (not the remote) and hold it pressed for 10 seconds and then release.
After approximately 15 seconds the LED on the Mede8er with flash red-blue and you will get a display of the progress of percentage installed on your TV display (some TV's will not display this) wait until the Mede8er re boots itself +- 180 sec. You Mede8er is now be updated.
« Last Edit: March 01, 2012, 07:22:25 am by Mede8er1 » Logged
