Author Topic: MED200X Firmware Update V1.5 -- 24Nov2011  (Read 3730 times)
  • Helpful Contribution Status: +94/-21
« on: November 27, 2011, 03:57:37 am »
New update for MED200X
Changelog V1.5
1) Fixed Alpha sorting on USB fat32 Drives
2) Changed screensaver image
3) Selection of Font A or B in Setup Menu
4) Fixed aac sound in MOV file
MED200X INTERNATIONAL VERSION
http://www.mede8er.org/beta/Firmware_Final/MED200X/MED200X_V1.5_24Nov.rar
MED200X THAI VERSION
http://www.mede8er.org/beta/Firmware_Final/MED200X/MED200X_V1.5_Thai_24Nov.rar
Update Procedure
UnZIP or UnRAR the file and you will find one file named install.img. Copy this file to the root directory of a Flash Drive. Plug the flash drive into the Mede8er. Disconnect the power jack at the rear of the Mede8er then plug it back in - Now press the on/off button on the Mede8er (not the remote) and hold it pressed for 10 seconds and then release.
After approximately 15 seconds the LED on the Mede8er with flash red-blue and you will get a display of the progress of percentage installed on your TV display (some TV's will not display this) wait until the Mede8er re boots itself +- 180 sec. You Mede8er is now be updated.
« Last Edit: March 01, 2012, 05:41:50 am by Mede8er1 »
