Author Topic: X2 IR Hex codes  (Read 18100 times)
X2 IR Hex codes
« on: November 26, 2011, 04:09:52 PM »
For reference attached you can find the IR Hex codes of the X2 Line.
(With thanks to getsko for supplying these).
« Last Edit: August 31, 2015, 09:25:55 PM by Maasbommel »
Offline mfhp
Re: X2 IR Hex codes
« Reply #1 on: September 27, 2016, 04:08:24 PM »
Thanks a lot for supplying these, work fine for me. One exception, though: there are two codes missing for buttons on the 500X2-Remote, please see attached image. I put a red rectangle around those two. When pressed during playback of e.g. a video file, Mede8er will do a time jump of several seconds forward or backward, respectively.
Could you please add these two codes?
Offline mfhp
Re: X2 IR Hex codes
« Reply #2 on: October 01, 2016, 02:57:47 PM »
OK, found them. See attached complete code list, I named the two "Jump forward" and "Jump backward" and added them at the end.
I used a small piece of hardware named "USB IrToy", and IrScrutinizer to find the codes. Using the codelist I built a configuration file for RCoid, an android app working as a smart IR remote. IMHO a great piece of software if you own a smartphone with IR blaster.
Re: X2 IR Hex codes
« Reply #3 on: October 01, 2016, 04:35:08 PM »
Thank you for taking the time to find your own solution and posting it.
Offline jpgrobler2
Re: X2 IR Hex codes
« Reply #4 on: January 16, 2020, 02:05:32 PM »
Can anyone please re-upload the file with the hex keys?
Re: X2 IR Hex codes
« Reply #5 on: January 17, 2020, 12:37:27 PM »
PM the poster.
Attachments where lost when the forum  moved to a new server host.
