Author Topic: Y2M Error - java.lang.NoClassDefFoundError: com/moviejukebox/MovieJukebox  (Read 486 times)
Flex
« on: November 25, 2011, 04:28:23 pm »
I have followed the user guide from http://www.mede8er.com/mede8er_y2m_user_guide.html but cant seem to get y2m to work.
I have extracted Y2M_BETA8_yamj-2.5-SNAPSHOT-r2665_64BIT_2Oct2011    to     c:\Y2M_BETA8_yamj-2.5-SNAPSHOT-r2665_64BIT_2Oct2011.
I have also made sure that my CLASSPATH and QTJAVA have been set correctly.
CLASSPATH  : C:\Program Files (x86)\Java\jre6_new\bin
QTJAVA         : C:\Program Files (x86)\Java\jre6_new\lib\ext\QTJava.zip
I pointed the YAMJ path to C:\Y2M_BETA8_yamj-2.5-SNAPSHOT-r2665_64BIT_2Oct2011\Y2M_BETA8_yamj-2.5-SNAPSHOT-r2665_64BIT_2Oct2011 and seems to be working because it populates the YAMJ properties section after doing this.
When I click done and  run YAMJ - I get this error  Error - java.lang.NoClassDefFoundError: com/moviejukebox/MovieJukebox.
Could any help shed some light on the problem please?
Ahari
« Reply #1 on: November 26, 2011, 09:30:21 am »
I'm not an expert by any means, but here is my 5 cents worth.
It may sound silly, but have you made sure you have the latest Java and .NET 3.5?
Try calling your folder YAMJ instead of that long name. Much easier to work with.
You may be doing what I did when I started which is selecting the actual jukebox folder in the YAMJ settings. Try selecting the folder in which you want the "jukebox" folder to be created. Don't select the actual "jukebox" folder.
Hope that makes sense.
MED500X2 with 2Tb drive - F/W v2.1.0 - Y2M Beta 8 r2882
