Pages: [1] 2 3 4   Go Down
Author Topic: Feedback MED500X2/400X2/450X2 -- V2.0.1 --- Latest 23 November 2011  (Read 3567 times)
Administr8or
« on: November 23, 2011, 01:50:59 pm »
Please post feedback on V2.0.1  for MED500X2/400X2/450X2  here
« Last Edit: November 23, 2011, 01:57:01 pm by Mede8er1 » Logged
marinero
« Reply #1 on: November 23, 2011, 05:11:04 pm »
hello
i am french and i'd like to know if it's possible to make a complete translation of the GUI, because there are a lot of words that are in english.
With the firm 1.03, in preview mode, there were infos about the videos, size, length....... this has disappeared in the 2.0??
cxax
X2 Skin Designer
« Reply #2 on: November 23, 2011, 07:12:35 pm »
I bought my MED500x2 few weeks ago. I updated the firmware to 2.0.0 and 2.0.1. In both versions I noticed a small problem in adding custom genre art to favourites.
I'd like to keep my genre arts, skins etc. on SD card and save the USB ports to play movies from a stick or external drive. I want to keep these data on SD card rather the internal drive because it's much easier for me to update data on the card only instead connecting MED500x2 to a PC.
I put the art files to the "genre" folder in SD card root - MED500x2 loads the files. However when I insert a usb stick it seems like MED500x2 search for the "genre" folder through usb ports only and don't load the art from SD card. When I remove the stick the files are back.
I didn't instaled the internal drive yet.
Does anyone noticed the same? Am I doing something wrong or it is a bug?
« Reply #3 on: November 23, 2011, 07:17:20 pm »
Can you still browse the SD card using Medialibrary with USB devices attached?
cxax
X2 Skin Designer
« Reply #4 on: November 23, 2011, 07:58:19 pm »
Sure. Everything works except loading the art files from "genre" folder.
« Reply #5 on: November 23, 2011, 08:01:56 pm »
You don't have a resource folder on the stick by any chance?
cxax
X2 Skin Designer
« Reply #6 on: November 23, 2011, 08:07:22 pm »
You mean folder named "resource" or "genre"? No, for sure there is no such folder on the stick.
Administr8or
« Reply #7 on: November 23, 2011, 09:11:34 pm »
Hi cxax
I  need to check this. Anyway I have a more elegant  way for you  to do your Favourite Genre Covers.
Download this pack of our default Genre covers
http://www.mede8er.org/artwork/temp/Genre_Images_23Nov2011.rar
Personalize them to your taste but save them as PNG and do not change the pixel xy size or file names.
Navigate to the folder that you saved these images to and press the 'Menu' Button and select the 'Set to Skin' option and the images will be stored in the X2 flash memory.
« Reply #8 on: November 23, 2011, 09:51:19 pm »
...meaning you can then remove the device you used to transfer them with..
cxax
X2 Skin Designer
« Reply #9 on: November 23, 2011, 09:57:50 pm »
Hi cxax
Great. I'm going to follow these steps. Indeed this seems more elegant and the SD card slot won't be occupied permanently. However it limits me to have only predefined genres while I'd like to create something more complex e.g. the GlynRS2 genres.
Meanwhile I've tried my configuration with another SD card and USB sticks - still the same. It seems like usb ports have priority and even if there is no "genre" folder the MED500x2 stops searching for the folder on SD card.
« Reply #10 on: November 23, 2011, 10:00:21 pm »
Try using resource/genre as the folder.
cxax
X2 Skin Designer
« Reply #11 on: November 23, 2011, 10:03:35 pm »
Believe me. Before I posted here I've tried many options including naming the folder "favourites" and "videowall". Still the same.
When the folder is named "genre" the art files are loaded if there is no usb stick, thus I assume that the issue is not the folder name.
« Reply #12 on: November 23, 2011, 10:08:45 pm »
Things get changed...and sometime earlier names still get supported at the same time.  So during development the correct folder has been genre, and resource/genre.
cxax
X2 Skin Designer
« Reply #13 on: November 23, 2011, 10:16:10 pm »
It doesn't matter if the folder "genre" is in root catalogue or "root/resource/genre" the problem still exist.
« Reply #14 on: November 23, 2011, 10:18:45 pm »
If the other devices is a semi-perment USB drive, why not put another copy of Genre on that?  If it's a stick then surely that dosn't stay permently?
That leaves the sd card for when nothing is attached.
This sounds like a bug..but we are trying to  think how you can progress for now.
Pages: [1] 2 3 4   Go Up
