Author Topic: New firmware and audio problem  (Read 830 times)
Gentcsar
« on: November 26, 2011, 07:14:02 pm »
I'm connected to my receiver with an optical cable, i have all setting up in menu (spdif passtrought, and AC3 or Dolby true HD,My receiver is setting on Pure direct, and the sound is in Stereo !!!
I cannot play a film in 5.1 ...From who come the problem ?
THX
Olivier
markt1891
B8a Tester - X2
« Reply #1 on: November 26, 2011, 07:16:50 pm »
Can you post some information on the media you are playing?  Perhaps using mediainfo...
http://mediainfo.sourceforge.net/en
Thanks,
Mark.
MED500X f/w v4.04 / MED400X2 f/w v2.0.1 / Denon AVR-F100 / 1gb Cat5e / Netgear GS716T-200 / Windows Home Server PP3 2 x 2tb / Panasonic TX-L37V10
« Reply #2 on: November 26, 2011, 07:22:08 pm »
Olivier,
Please also post:
- what brand/type receiver you are using
- what firmware version you have installed on your Mede8er (please mention version number and not say latest)
- how things are connected (eg mede8er by HDMI to TV, and by SPDIF to amp)
- what setting you use under mede8er video setup and audio setup
Gentcsar
« Reply #3 on: November 26, 2011, 07:34:56 pm »
This is this file
http://www.trailerz.demo-world.eu/hd/hd_dts_orchestra_long.rar
My firmware is V 2.0.1 on Med500X2
My receiver "amplifier" is a DENON AVC A1SR
Connected in optical mode
The Mede8er is connected on HDMI to my Projector Sony VPL VW60
Audio is setting up to SPDIF :Passtrought and AC3
Video on HDMI in 1080P24 active
« Last Edit: November 26, 2011, 07:40:40 pm by Gentcsar » Logged
« Reply #4 on: November 27, 2011, 12:22:42 pm »
Gentscar,
If you upgraded to 2.0.1 version, did you had the same problem with a previous firmware version?
« Last Edit: November 27, 2011, 05:48:51 pm by Maasbommel » Logged
« Reply #5 on: November 27, 2011, 12:35:25 pm »
I have a similar problem with my Receiver Denon AVC A1SR, connected with optical cable for sound and HDMI to my projector, but unable to have a 5.1 sound, only stereo ... On my receiver i'm on Pure direct mode .
Is it possible to try using analog video with no hdmi connected...after a full power down? Modern systems use what is called cea-edid,,informationsupplied over HDMI which tells a source what audio is supported.  Now there should be a fix for analog system which get no edid in V2 GUI, that should work. This is a test...not a solution.   Projectors may not support cea-edid, but the fact HDMI is being used  might mean we have found a new issue..HDMI systems which produce null cea-edid.
Gentcsar
« Reply #6 on: November 27, 2011, 05:35:32 pm »
Hello, All informations are there ... Thank for your help
http://www.mede8erforum.com/index.php/topic,7225.0.html
« Reply #7 on: November 27, 2011, 05:47:52 pm »
I just merged you topics again to one, that will keep things a bit more clear....
Please look at the suggestion of Jer1956 and suggest to give that a try.
And also:
Gentcsar
« Reply #8 on: November 28, 2011, 12:36:23 am »
I'm going tonight in 1.03 firmware, and now problem is the same with older firmware !!! audio only in stereo ... Cry
and unable Cry to connect to my mac pro (Lion)
« Reply #9 on: November 28, 2011, 11:24:56 am »
You will find plenty of posts on Lion not working.....it's a big problem created by Apple!
« Reply #10 on: November 28, 2011, 11:46:40 am »
Did you already try what jer1956 suggested to test:
http://www.mede8erforum.com/index.php/topic,7225.msg46103.html#msg46103
qball
« Reply #11 on: November 28, 2011, 05:39:50 pm »
THX
Olivier
I think Pure Direct is for 2-channel listening only.
« Reply #12 on: November 28, 2011, 05:48:49 pm »
Quote from Denon:
"Stereo with an analogue input, stays analogue as it passes through an analogue High-Pass Filter (if the speakers are configured to small) while a seperate but parallel signal goes to the DSP for Low-Pass filtering. In DIRECT Mode the Hi-Pass Filter is bypassed, while the digital Low-Pass is still active. In PURE DIRECT Mode, both the analogue High-Pass and digital Low-Pass are bypassed, however an analogue Low-Pass takes over, so in PURE DIRECT it is 100% analogue"
So Pure Direct avoids the digital pre-amp when using high quality analog stereo inputs.
