Author Topic: [TIP] Howto customize GUI font or Subtitle font  (Read 1594 times)
« on: November 22, 2011, 12:38:41 am »
(Based on V2.0.0 firmware or higher).
To change the GUI (Grafical User Interface):
1] Create a folder on a source (usb, internal disk, network share)
2] In this folder place the desired .ttf font and name it gui.ttf
3] Now browse in Media Library to the source folder so it is highlighted (go not into it)
4] Press on the menu button on the remote and select Set to Skin. The new font will now be loaded.
To change the subtitle font:
2] In this folder place the desired .ttf font and name it subtitle.ttf
You can find free ttf fonts here:
http://www.1001freefonts.com/
To reset to default font. Highligth a folder in Media Library and press Menu.
Now select: Restore Skin Default
After a font change or other Skin change, always first reboot your Mede8er for stable performance.
