Author Topic: ThumbGen Settings For MEDE8ER  (Read 2623 times)
shadowgp
« on: November 16, 2011, 05:18:26 pm »
Can someone give the settings that i sould use in ThumbGen...
in order to have the right XML file, about and folder for MEDE8ER?
Thanx!
MedeUser
« Reply #1 on: November 23, 2011, 11:53:48 am »
Check this post: http://www.mede8erforum.com/index.php/topic,7082.0.html. Very clear instructions!
sandom
« Reply #2 on: November 23, 2011, 01:21:50 pm »
I think you are better off reading this: http://www.mede8erforum.com/index.php/topic,2006.0.html
First post after it says: Practically you can use it right now if you do following:....
« Reply #3 on: November 23, 2011, 02:06:51 pm »
That one is very old..... and also a lot about old Thumbgen versions.
tachita_
Senior Member
« Reply #4 on: November 23, 2011, 04:05:33 pm »
@shadowgp
try latest thumbgen and free your mind ...
you can do anything with TB  Wink
