Author Topic: [TIP] Howto check if your internal Mede8er disk is formatted with Mede8er setup  (Read 1574 times)
« on: December 28, 2009, 08:36:54 pm »
 - Connect your Mede8er to your PC via USB
 - Click Start > Run and type diskmgmt.msc
 - View the drive that appears as your Mede8er
 - If it was formatted by the Mede8er then it will have one large NTFS partition and 2 smaller 'unknown' partitions
« Last Edit: January 18, 2010, 03:50:41 pm by Maasbommel » Logged
Panasonic SA-PTX5
Insomniac
Moder8or
Administr8or
« Reply #1 on: January 16, 2010, 07:52:01 pm »
Another way:
You could Telnet into your Mede8er IP and provide the FDISK -L output:
1. On Mede8er - determine your network IP Address:
  o System Setup > Network > Wired LAN / Wireless Setup
2. Provide the FDISK -L output of Mede8er drive:
  o From PC, click on START > RUN
  o Type in HYPERTRM and ENTER
  o Create a new connection, call it Mede8er
  o Connect using TCP/IP (Winsock)
  o In Host Address, type in IP address of your Mede8er as determined in point 1 above
  o Leave Port as 23
  o From LOGIN prompt, enter ROOT and hit ENTER
  o Now type in fdisk -l and ENTER
Post the output, you should have something like this:
Code:
/ # fdisk -l
Disk /dev/sda: 1000.2 GB, 1000204886016 bytes
255 heads, 63 sectors/track, 121601 cylinders
Units = cylinders of 16065 * 512 = 8225280 bytes
   Device Boot    Start       End    Blocks   Id  System
/dev/sda1               2      121541   976270050    7  HPFS/NTFS
/dev/sda2          121542      121561      160650   82  Linux swap
/dev/sda3          121562      121581      160650   83  Linux
« Reply #2 on: April 26, 2010, 05:25:08 pm »
With Windows7 follow Insomniacs instruction but use the Telnet Client. This is not installed unless requested.
Goto Control Panel - Programs - Turn Windows Features on or Off, and tick the Telnet Client box.
Run the Command Prompt - and Type "Telnet" followed by the Med500x IP address (without leading zero's in last two fields).
« Last Edit: June 05, 2010, 04:43:39 pm by jer1956 » Logged
