Pages: 1 2 [3] 4   Go Down
Author Topic: General discussion about Y2M V1BETA8  (Read 9123 times)
the-osiris
B8a Tester - 1000X3D
« Reply #30 on: January 11, 2012, 11:57:19 am »
get the same errors, and it bombs out - I have even gone as far as reloading my computer, no luck. Beta 7 worked fine - Beta 8 is a peice of rubbish - going back to Thumgen
You are free to choose between using Y2M or any other program as you like, Y2M is depends on IMDb and YAMJ, IMDb keep updating their sites as YAMJ also did, bugs is inevitable.
We are grateful having Peter Butler to gave his time in developing Y2M, I'm sure he's noticed about those bugs and we can only wait for an update, in a while, you may use many other scraping program.
MED450X2 V2.0.7 :p
MED1000X3D V2.0b
LG 42LE5500 HDMI
the-osiris
« Reply #31 on: January 12, 2012, 08:46:45 am »
Well done !!  Grin
Y2M Update V1BETA8-YAMJ-r2882-12 Jan2012 ( LATEST )
http://www.mede8erforum.com/index.php/topic,7762.0.html
thanx Peter and Mede8er1 !
MED450X2 V2.0.7 :p
MED1000X3D V2.0b
LG 42LE5500 HDMI
jonas9000
« Reply #32 on: January 12, 2012, 11:01:33 am »
I will retry tonight, if same result i will send log + screenshots ! Thanks.
king_helm
« Reply #33 on: January 16, 2012, 06:30:56 pm »
I have a VIDEO_TS of Immortals and when i try to scan it with YAMJ i get the following without any result:
Processing started at Mon Jan 16 17:29:19 CET 2012
Using properties file ./properties/moviejukebox-default.properties
Using properties file moviejukebox-Mede8er.properties
Using properties file ./skins/default/skin.properties
Using properties file ./skins/default/skin-user.properties
Using properties file ./properties/apikeys.properties
Got libraryRoot from properties file: E:/Movie Collection/Immortals (2011) HD/
Using 1 processing threads and 1 downloading threads...
See README.TXT for increasing performance using these settings.
Preparing environment...
Initializing...
Scanning library directory E:\Movie Collection\Immortals (2011) HD
Jukebox output goes to E:\YAMJ
    Scanning directory #1, 2 files scannedjava.lang.StringIndexOutOfBoundsException: String index out of range: -1
   at java.lang.String.substring(Unknown Source)
   at com.moviejukebox.scanner.MovieDirectoryScanner.scanFile(MovieDirectoryScanner.java:281)
   at com.moviejukebox.scanner.MovieDirectoryScanner.scanDirectory(MovieDirectoryScanner.java:151)
   at com.moviejukebox.scanner.MovieDirectoryScanner.scan(MovieDirectoryScanner.java:115)
   at com.moviejukebox.MovieJukebox$2.call(MovieJukebox.java:921)
   at com.moviejukebox.MovieJukebox$2.call(MovieJukebox.java:916)
   at java.util.concurrent.FutureTask$Sync.innerRun(Unknown Source)
   at java.util.concurrent.FutureTask.run(Unknown Source)
   at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Unknown Source)
   at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
   at java.lang.Thread.run(Unknown Source)
   at com.moviejukebox.tools.ThreadExecutor$ScheduledThread.run(ThreadExecutor.java:114)
Found 0 videos in your media library
Stored 5 files in the info cache
MovieJukebox process completed at Mon Jan 16 17:29:20 CET 2012
Processing took 00:00:01
Mede8er MED500x - 2TB internal HDD
Samsung 46" LED tv
Xbox 360 Pro
Nintendo Wii
« Reply #34 on: January 16, 2012, 07:50:27 pm »
Point Y2M to E:\Movie Collection to scan and not to the movie path below.
reevesy
« Reply #35 on: January 30, 2012, 01:23:56 pm »
hi all
has anyone got the guy ritchie film 'Snatch' via yam
if so what searchpath didi you use........i've tried loads and only get a result of 'the big snatch'!
notoo intrested in big snatches  Grin
cheers
Maat236
« Reply #36 on: February 02, 2012, 02:01:21 am »
hi all
cheers
Sure. Create new empty text file and rename it to the same name as your movie, but replace .txt file extension with .nfo file extension. Edit this empty text file, and just copy IMDB movie title link for this movie (Snatch) into this text file.
In this case that would be:
http://www.imdb.com/title/tt0208092/
Save and exit .nfo file.
Run Y2M again, it will work now because this .nfo file will direct Y2M to the correct Movie title at IMDB.
You can do this for every movie, making sure that you put .nfo file in the folder with the same movie and of course filename of .nfo file should be exactly the same as movie file. Works great with non-recognized movies by Y2M.
reevesy
« Reply #37 on: February 02, 2012, 10:49:55 am »
thanks mate
cheers worked a treat.....although the background picture on the 'about' graphic is'nt from the film?
cheers
Maat236
« Reply #38 on: February 02, 2012, 03:37:08 pm »
thanks mate
cheers
You're welcome. I'm glad it worked. I don't understand why the 'about' picture isn't from the movie. Y2M is supposed to pick up original cover art from IMDB. Maybe IMDB has problems again... Although, I don't have imdb.site=us in configuration, but imdb.site=labs. I set this option to maintain original movie titles, in order not to get translated (localized - Croatian) movie titles. Sometimes cover art is different too...
Loewe81
« Reply #39 on: February 15, 2012, 08:52:19 am »
Hi there,
for now I have the following two questions:
1. In which file are the positions and sizes for the different areas (title, duration, plot, genre, actors etc.) defined. I want to do some modification of the template (repostion and resizing of some areas) and I think I have enough knowledge to do this, but at the moment I didn't find where. I'm only looking for the template of the standard movie page (about.jpg).
2. YAMJ is downloading the fanart and the cover for the folder view automatically. Is there any option to choose between different images (for most movies there are several fanarts and covers available, I guess YAMJ is always using the "first" one)? Would be great if I could manually decide, which image to use. If that's not possible within the tool itself, I guess I can download the necessary images by myself, but where do I have to place it and which filename do they need?
Thank you!
Ciao Stefan Smiley
MED500X v4.0.4 MOD
Data: QNAP NAS connected via WLAN
Audio: SPDIF passthrough via optical to Yamaha RX-V650
Video: 720p 60Hz via HDMI to Panasonic TH-42PX80EA
marcepa
B8a Tester - X2
« Reply #40 on: February 15, 2012, 10:36:14 am »
You may have a look at YAYMAN (see google)
Loewe81
« Reply #41 on: February 15, 2012, 11:31:08 am »
Thank you marcepa, will give it a try.
Another question, how can I disable the Mede8er-Logo on the bottom right?
It's not possible to define its size to zero or to position it outside of the visible area.
Deleting the image file (where is it located) or is there an official setting, where I can disable it?
Thank you!
Ciao Stefan Smiley
MED500X v4.0.4 MOD
Loewe81
« Reply #42 on: March 02, 2012, 02:09:33 pm »
From which site is YAMJ downloading the covers for the folder.jpg?
Can this be edited in the properties and if yes with which key?
I'm asking because I'm looking for German covers, at the moment I got always the english version, where the title is also different from the German one.
:EDIT: For all the german people here, it seems to be the language-key in the themoviedb-category. I set it to "de" and then I got the german covers. I also tried the country-key and changed it from "US" to "DE", but this was making no differences.
Thank you!
Ciao Stefan Smiley
« Last Edit: March 02, 2012, 02:51:23 pm by Loewe81 » Logged
MED500X v4.0.4 MOD
Antonjo
« Reply #43 on: March 03, 2012, 11:40:05 pm »
What am I supposed to do if I want to see language and country info on about.jpg
king_helm
« Reply #44 on: March 04, 2012, 07:54:31 pm »
Hi guys,
currently i am constantly getting this error and it fails to produce the background image:
Stored 37 files in the info cache
Searching for information on the video files...
MediaInfo tool will be used to extract video data
Processing new video: Warrior
Failed retreiving IMDb data for movie : tt1291584
java.lang.StringIndexOutOfBoundsException: String index out of range: -38
   at com.moviejukebox.plugin.ImdbPlugin.updateInfoNew(ImdbPlugin.java:851)
   at com.moviejukebox.plugin.ImdbPlugin.updateImdbMediaInfo(ImdbPlugin.java:236)
   at com.moviejukebox.plugin.ImdbPlugin.scan(ImdbPlugin.java:124)
   at com.moviejukebox.plugin.DatabasePluginController.scan(DatabasePluginController.java:74)
   at com.moviejukebox.MovieJukebox.updateMovieData(MovieJukebox.java:1808)
   at com.moviejukebox.MovieJukebox$3.call(MovieJukebox.java:978)
   at com.moviejukebox.MovieJukebox$3.call(MovieJukebox.java:963)
What is the problem here and how can i solve it? Thanks!
Samsung 46" LED tv
Xbox 360 Pro
Nintendo Wii
Pages: 1 2 [3] 4   Go Up
