Author Topic: .file.jpg hangs up the 500X2  (Read 1962 times)
Offline Brenzef
« on: November 02, 2011, 07:22:01 pm »
My guess was that the 500X2 runs Linux under the hood and therefore should be able to hide movie jpegs by hiding them the Unix way. This means that a file should start with a dot, such as .avatar.jpg
However this resulted in a frozen menu screen until I renamed them back to file names without a starting dot.
You can support me by buying your stuff on Bol dot com through http://www.vegetarisme.nl/bol
Cost you nothing, gives me some dinero's to keep the site running.
Thanks...
Re: .file.jpg hangs up the 500X2
« Reply #1 on: November 02, 2011, 07:44:08 pm »
The underlying os is linux, but the Gui is partly based on a propriety Realtek SDK.
And that is not using these filenames with a . to hide files.
« Reply #2 on: November 02, 2011, 07:46:35 pm »
User files are not stored on linux partition. Would you expect the NTFS emulator to obey linux rules?
Offline Brenzef
« Reply #3 on: November 02, 2011, 09:43:35 pm »
I understand both replies. not be able to use dotted files is no issue.
I renamed them to folder.jpg. that makes them invisible too..
Thanks...
« Reply #4 on: November 02, 2011, 09:57:16 pm »
Removing makes them invisable also  ;D
« Reply #5 on: November 02, 2011, 10:01:12 pm »
I think you can also put a $ sign in front of the file name. That might mask (hide them) too.
