Author Topic: TViXIE-2-M8R  (Read 99248 times)
Offline Qoissi
Re: TViXIE-2-M8R
« Reply #60 on: January 03, 2016, 04:38:00 PM »
Just to share a simple Python program I just did to do a similar job.
It removes useless files:
  folder.ico
  icon.tvix
It renames files that need to:
It generates the X3D XML file from the MovieInfo.tvixie XML file (without removing it).
Converted fields are:
- Title
- Year
- Runtime (converted in "Xh XXm" format)
- Rating
- Plot
- Director
- Certification
- Country
- Genres
- Cast
Works with Python installed with lxml module.
Just pass the root directory in argument and it loops over all sub directories to convert them.
In a command prompt just type:
Code: [Select]
python tvix2x3d.py -d <your root directory>
If this can help anyone ;-)
