Author Topic: TViXIE-2-M8R  (Read 99249 times)
Offline K0BUZ
Re: TViXIE-2-M8R
« Reply #30 on: September 02, 2012, 12:15:31 PM »
Decimal symbol is , and number of decimals 2.
The regional setting would be Dutch.
Offline Skylinc
Re: TViXIE-2-M8R
« Reply #31 on: September 02, 2012, 12:18:34 PM »
Changing my region to Dutch gives me 800. I will fix this and update (now that I know how to replicate the problem).
Audio: HDMI > LG 42LW4500
Offline K0BUZ
Re: TViXIE-2-M8R
« Reply #32 on: September 02, 2012, 12:20:51 PM »
That would be great, thanks!  8)
Offline Skylinc
Re: TViXIE-2-M8R
« Reply #33 on: September 02, 2012, 12:39:18 PM »
The .Net version has been updated, and can be downloaded from the original post.
Thanks for pointing it out, and for the assistance in solving it!
Offline K0BUZ
Re: TViXIE-2-M8R
« Reply #34 on: September 02, 2012, 01:20:33 PM »
Thanks! Tested it, and runs perfect now!  :)
Offline vartanig
Re: TViXIE-2-M8R
« Reply #35 on: September 21, 2012, 10:59:15 AM »
Hey there!
Im having a little trouble doing this. I new at this so I hope you guys have a bit patiens.
I´ve used Tvixie when I had my TiviX before and am very satisfied with it and wanto continue using tvixie.
Now, when I choose the root directory where my movies are, it converts it to xml and to xml.m8r.
Then what am I suppose to do. When I go into the library in my X3 i can only see the covers of all the movies. When i enter the folder i see the .mkv file and the .jpg that I created with tvixie.
What exactly am I suppose to do with the .xml file?
/V
Offline Skylinc
Re: TViXIE-2-M8R
« Reply #36 on: September 21, 2012, 11:04:33 AM »
Hi vartanig
The XML file is read by the Mede8er (probably exactly as the Tvixie use the tvixie file). When you have Jukebox mode set to ON, you will see the info from the XML file without needing to open "about.jpg" (by pressing the Enter button).
You will also need to scan your collection once Jukebox view has been set to ON so that the Mede8er knows about everything ;)
Offline Skylinc
Re: TViXIE-2-M8R
« Reply #37 on: September 21, 2012, 11:05:48 AM »
This will only happen if you already have XML files in the directory, and you have not opted to overwrite existing files (it's a backup of the original XML file)
Offline vartanig
Re: TViXIE-2-M8R
« Reply #38 on: September 21, 2012, 11:29:54 AM »
Thanks for answer. Stil not geting it to work though. Im doing something wrong here. :(
Offline Skylinc
Re: Re: TViXIE-2-M8R
« Reply #39 on: September 21, 2012, 11:31:50 AM »
I will check tonight when I get home and revert with an answer.
Sent from my GT-I9300 using Tapatalk 2
Offline Skylinc
Re: TViXIE-2-M8R
« Reply #40 on: September 22, 2012, 09:21:11 AM »
@vartanig, please see the attached screen shot of what it should look like after you've converted the TViXIE files to XML. (I've highlighted in red what should be different)
If you don't see that, then press the Menu button on your remote, and make sure to click "Show Movie Info".
Please note, you don't have to scan your collection, or set Jukebox mode on for this to work.
Offline vartanig
Re: TViXIE-2-M8R
« Reply #41 on: September 22, 2012, 10:59:37 PM »
Hey again :)
The info you showed me Im getting. But when I press on the coverart you suppose to get fan art with movie info etc. This is what I have trouble getting.
Offline Skylinc
« Reply #42 on: September 22, 2012, 11:03:25 PM »
You can get that by pressing the Info button on your remote (if about.jpg exists). I believe if you are in the favourites then the Enter button will work as well, but will test that tomorrow.
Offline Skylinc
Re: TViXIE-2-M8R
« Reply #43 on: November 06, 2012, 08:53:50 PM »
Bump. Minor updates to both version :)
Offline Skylinc
Re: TViXIE-2-M8R
« Reply #44 on: November 07, 2012, 06:35:54 PM »
Sorry for the extra bump. Some bugs fixed, please see first post.
