Gogsysul
Offline
« Reply #15 on: June 11, 2012, 02:48:07 pm » |
Skylinc
« Reply #16 on: June 11, 2012, 02:56:49 pm » |
Oh dear! That does look serious... I'm not the author of tvixie, so maybe you can download a "cached" version from here: http://tvixie.software.informer.com/
Product: Mede8er MED1000X3D f/w v2.0.0 (5Feb2013) Audio: HDMI > LG 42LW4500 Audio setting: HDMI Passthrough / Night mode Comfort Video: HDMI output > LG 42" LED Cinema3D 42LW4500 Video setting: 1080p 50Hz, 23Hz ON,16:9 Media Source: Wired Network > Win 8 Professional SMB shares, OpenMediaVault Shares Hard Drive: 2TB Western Digital
Gogsysul
Offline
« Reply #17 on: June 11, 2012, 03:47:08 pm » |
Thanks m8 Was also interested in the forums, looking for info on whether theres a template for TV Series??? Thanks again
Krijger
Offline
« Reply #18 on: June 11, 2012, 04:19:21 pm » |
Software informer only has tvixie version 1.3.1 to download...
Skylinc
« Reply #19 on: June 11, 2012, 04:36:27 pm » |
Sadly I don't even have the setup file for the latest version, otherwise I could've helped out
Skylinc
« Reply #20 on: June 11, 2012, 04:37:36 pm » |
I don't think there is a template for TV Series, as the program is not as configurable as Thumbgen. I use TViXIE purely for movies, and thumbgen for Series.
Gogsysul
Offline
« Reply #21 on: June 11, 2012, 05:56:28 pm » |
Yeah, thats what i thought.. Was more hope than anything else  I'm using Thumbgen for TV Series and YAMJ for movies Was just hoping TVixie would support TV Series as some of the family, just cant get to grips with Thumbgen! It would have saved me going round to sort it for them every so often  Thanks for the info though m8
bernieb
Offline
« Reply #22 on: June 17, 2012, 04:41:11 pm » |
In case someone still needs TVIXIE please contact me. I still have the file TViXiE-1.3.3-setup.zip
Skylinc
« Reply #23 on: June 17, 2012, 07:16:39 pm » |
Hi Bernie. I'll be interested. Will PM you next week though as I'm out of town....
Sent from my Samsung Galaxy S3 using Tapatalk 2
Skylinc
« Reply #24 on: August 04, 2012, 08:26:22 pm » |
Bump! Additional changes made. See first post for changes and downloads. Also a side-note: Tvixie website is working again!
K0BUZ
Offline
« Reply #25 on: September 02, 2012, 11:26:28 am » |
Great app!
The java version would not allways convert the actor information that was in the .tvixie file. A problem the windows version does not seam to have, all actor info is now there. Only problem I have is that the ratings are all 10/10. <rating>800</rating> shouldn't this be <rating>80</rating> ?
Hope you can fix this? Love tvixie, so hope you keep working on the .xml converter!
Skylinc
« Reply #26 on: September 02, 2012, 11:48:37 am » |
I will have a look at that today, and update! Thanks for the feedback
Skylinc
« Reply #27 on: September 02, 2012, 11:58:50 am » |
Could you send me the tvixie file for this movie? I've checked mine, and they all seem fine (5.2 => 52). Also, are you using the Java version or the .Net version?
K0BUZ
Offline
« Reply #28 on: September 02, 2012, 02:00:33 pm » |
Here are the two files, the tvixie and the xml file. I used the .net version for the xml conversion.
Edit: Just looked at my Cars.xml.m8r file, and that has the correct rating of 80 instead of 800 which is in the Cars.xml file.
« Last Edit: September 02, 2012, 02:05:41 pm by K0BUZ »
Skylinc
« Reply #29 on: September 02, 2012, 02:09:29 pm » |
I ran the file on my side, and it converts fine. Can you tell me what your regional settings are (specifically the Decimal Symbol)?
