Pages: [1] 2 3   Go Down
Author Topic: Movies won't rewind!  (Read 1959 times)
Ahari
« on: October 21, 2011, 03:58:53 pm »
My new 500X2 won't rewind .mkv movies!   Sad Is this something wrong with my player or is it a bug in the firmware? Am I doing something wrong?
Fast forward works fine - really cool the way it also speeds up the sound!
Help!
MED500X2 with 2Tb drive - F/W v2.1.0 - Y2M Beta 8 r2882
« Reply #1 on: October 21, 2011, 04:07:13 pm »
Please read the guidelines for posting media problems. Use mediainfo (on a PC) to extract information from the file.
We have lots of advice on how to make you own MKV's. If they are torrents. well we have no idea how those where made. PC MKV players are desinged to deal with th badly encoded media found on torrent. VLC prides itslef on doing that. But hardware players have no such flexibility or tolerence.
Ahari
« Reply #2 on: October 21, 2011, 04:36:41 pm »
Sorry I posted in the wrong place! I'm very new at both players and forums - this is the first forum I have ever joined!
I opened the file in MediaInfo and got this:
Code:
General
Unique ID                        : 332693677778853846304298388885043916739 (0xFA4A78BD05DFEFB213E6C4886A77AFC3)
Complete name                    : J:\My Videos\Movies\Animation\_Kyle\Ice Age\03 Ice Age 3 Dawn of the Dinosaurs (2009)\Ice Age 3 Dawn of the Dinosaurs (2009).mkv
Format                           : Matroska
Format version                   : Version 2
File size                        : 3.33 GiB
Duration                         : 1h 30mn
Overall bit rate mode            : Variable
Overall bit rate                 : 5 291 Kbps
Encoded date                     : UTC 2011-10-14 21:15:51
Writing application              : MakeMKV v1.6.15 win(x86-release)
Writing library                  : libmakemkv v1.6.15 (1.2.0/1.1.0) win(x86-release)
Video
Format                           : MPEG Video
Format profile                   : Main@Main
Format settings, BVOP            : No
Format settings, Matrix          : Custom
Codec ID                         : V_MPEG2
Codec ID/Info                    : MPEG 1 or 2 Video
Duration                         : 1h 30mn
Bit rate mode                    : Variable
Bit rate                         : 4 545 Kbps
Maximum bit rate                 : 9 800 Kbps
Width                            : 720 pixels
Height                           : 576 pixels
Display aspect ratio             : 16:9
Frame rate                       : 25.000 fps
Standard                         : Component
Color space                      : YUV
Chroma subsampling               : 4:2:0
Bit depth                        : 8 bits
Scan type                        : Progressive
Scan order                       : Top Field First
Compression mode                 : Lossy
Bits/(Pixel*Frame)               : 0.438
Stream size                      : 2.86 GiB (86%)
Language                         : English
Audio #1
Format                           : AC-3
Format/Info                      : Audio Coding 3
Mode extension                   : CM (complete main)
Codec ID                         : A_AC3
Duration                         : 1h 30mn
Bit rate mode                    : Constant
Bit rate                         : 448 Kbps
Channel(s)                       : 6 channels
Channel positions                : Front: L C R, Side: L R, LFE
Sampling rate                    : 48.0 KHz
Bit depth                        : 16 bits
Stream size                      : 289 MiB (8%)
Title                            : 3/2+1
Language                         : English
Audio #2
Format                           : AC-3
Format profile                   : Dolby Digital
Codec ID                         : A_AC3
Duration                         : 1h 30mn
Bit rate                         : 192 Kbps
Channel(s)                       : 2 channels
Channel positions                : Front: L R
Bit depth                        : 16 bits
Stream size                      : 124 MiB (4%)
Title                            : 2/0
Language                         : English
Text
Format                           : VobSub
Codec ID                         : S_VOBSUB
Codec ID/Info                    : The same subtitle format used on DVDs
Language                         : English
Menu
00:00:00.000                     : en:Chapter 01
00:03:03.528                     : en:Chapter 02
00:10:13.208                     : en:Chapter 03
00:15:26.608                     : en:Chapter 04
00:19:11.808                     : en:Chapter 05
00:23:08.888                     : en:Chapter 06
00:26:22.648                     : en:Chapter 07
00:30:29.968                     : en:Chapter 08
00:34:42.128                     : en:Chapter 09
00:39:30.888                     : en:Chapter 10
00:46:30.448                     : en:Chapter 11
00:48:42.088                     : en:Chapter 12
00:54:43.368                     : en:Chapter 13
00:55:43.448                     : en:Chapter 14
01:00:36.528                     : en:Chapter 15
01:05:18.248                     : en:Chapter 16
01:08:41.568                     : en:Chapter 17
01:12:54.048                     : en:Chapter 18
01:17:46.328                     : en:Chapter 19
01:23:17.048                     : en:Chapter 20
I made the mkv for the player myself using MakeMKV after ripping the original DVD with RipIt4Me and DVDShrink. The original rip was done some time ago as it was meant to fit onto an ordinary DVD. I changed over to mkv because it is more elegant and generally easier to use on the player. I have lots of these all done in the same way. None of them rewind!
I think that is all that is relevant to my issue. Is there any further info that is needed?
« Reply #3 on: October 21, 2011, 04:55:02 pm »
Download MKVtoolnix and use MKVMerge GUI to remux. We don't get a lot of mpeg2 mkv's. Most people are converting to H264. Try remuxing first, transcoding takes far to long amd might not work.
Ahari
« Reply #4 on: October 21, 2011, 10:29:25 pm »
Thanks jer1956 for the quick response!
So what you are saying is that my mpeg 2 videos won't play properly in the 500X2 and that I need to remux them all to H264?
I don't understand how the 500X2 can struggle with formats that have been around for ages?
If you are sure then I will give it a try. I would rather learn this now before I copy everything over and spend ages sorting them and converting straight to mkv.
I just thought that DVD shrink although old was still good? Has always just worked for me.
I don't have any HD stuff yet - is that the reason for h264? I do plan on going HD in the near future, I suppose I just need to take this opportunity to sort out all my old files!
« Reply #5 on: October 21, 2011, 10:32:42 pm »
No!
Remuxing using differnt muxing software should be tried first.
Ahari
« Reply #6 on: October 21, 2011, 10:37:46 pm »
Now I'm confused!
What must I do with my files?
Which software should I use?
the-osiris
B8a Tester - 1000X3D
« Reply #7 on: October 22, 2011, 01:37:17 am »
Using MKVToolnix, there's a one tool called MKVMergeGUI (GUI for MKVMerge),
http://www.bunkus.org/videotools/mkvtoolnix/
put your MKV into input file menu, click start muxing, it quite fast - it will remux your video and audio into an MKV file again. try to play this file and post the result here.
MED450X2 V2.0.7 :p
MED1000X3D V2.0b
LG 42LE5500 HDMI
Ahari
« Reply #8 on: October 22, 2011, 11:40:59 am »
You don't sleep! Thanks for the reply.
I did as you said, but it didn't work. The file still won't play in reverse!  Cry
What does remuxing like that do to the file? I also ran the resultant file through MediaInfo and got this:
Code:
General
Unique ID                        : 236419345035592651584179128258256866013 (0xB1DCB5A895A721CABC78C6DCEFA28ADD)
Complete name                    : J:\My Videos\Mede8er\Movies\Animation\_Kyle\Ice Age\03 Ice Age 3 Dawn of the Dinosaurs (2009)\Ice Age 3 Dawn of the Dinosaurs (2009) (1).mkv
Format                           : Matroska
Duration                         : 1h 30mn
Overall bit rate                 : 5 286 Kbps
Encoded date                     : UTC 2011-10-21 22:07:39
Writing application              : mkvmerge v5.0.1 ('Es ist Sommer') built on Oct  9 2011 11:55:43
Writing library                  : libebml v1.2.2 + libmatroska v1.3.0
Video
Format                           : MPEG Video
Codec ID                         : V_MPEG2
Duration                         : 1h 30mn
Bit rate                         : 4 540 Kbps
Width                            : 720 pixels
Height                           : 576 pixels
Color space                      : YUV
Bit depth                        : 8 bits
Language                         : English
Audio #1
Format                           : AC-3
Muxing mode                      : Header stripping
Codec ID                         : A_AC3
Duration                         : 1h 30mn
Bit rate                         : 448 Kbps
Bit depth                        : 16 bits
Title                            : 3/2+1
Language                         : English
Audio #2
Format                           : AC-3
Codec ID                         : A_AC3
Duration                         : 1h 30mn
Bit rate                         : 192 Kbps
Bit depth                        : 16 bits
Title                            : 2/0
Language                         : English
Text
Format                           : VobSub
Muxing mode                      : zlib
Codec ID                         : S_VOBSUB
Language                         : English
Menu
I'm no expert, but it looks much the same to me.
When I try to rewind, the movie just freezes until I press play again. Same as the original mkv.
What do I try now?
jaunedoeuf
« Reply #9 on: October 22, 2011, 07:38:20 pm »
Try with a short name and short path
Your file is located :
Try to rename it and move it like :
J:\movietest.mkv
and tell us what this will do.
A odd thing :
Code:
If the video is progressive, then it doesn't have a top and bottom field.
If it have a top and bottom field, it is not progressive but interlaced.
I believe mkvmerge doesn't recognize the video correctly and therefore it write false information about the viideo making it difficult to read by the player.
Ahari
« Reply #10 on: October 22, 2011, 11:41:30 pm »
Hi jaunedoeuf,
Thanks for the idea - I tried moving the file to the root of the drive - no change!
The scan type and order you mention is meaningless to me! Sorry. Any ideas how I can fix it?
This is not the only file I have that does this.
tachita_
Senior Member
« Reply #11 on: October 23, 2011, 01:33:08 am »
sh.t and sh.t all over the place....
the problem is in encoder...  fields problems will stunt you if will be so
turn your video into new file..  re-encode
the-osiris
« Reply #12 on: October 23, 2011, 03:59:16 am »
yeah .. it's inevitable.
MED450X2 V2.0.7 :p
MED1000X3D V2.0b
LG 42LE5500 HDMI
Ahari
« Reply #13 on: October 23, 2011, 08:10:06 am »
Major bummer!  Sad So you reckon the field problem is the issue?
If you guys say that's what I gotta do, then I gotta do it! Better now than later.
1. What software should I use and what codec? These are all SD movies. I think it affects most of my movies!!!  Angry
2. What have I been doing wrong? I need to work out what is causing the problem so I don't keep doing it. Is it because I have been using such old software? If so, I can't understand why as RipIt4ME, DVDShrink and DVD Decrypter seem to be well respected all over the place.
3. What do you recommend I use in future to rip with so as to avoid this problem?
4. The Mede8er seems to be the only thing that struggles with my files. All the software players have no problems at all. Why is Mede8er so picky!? I thought it was specifically designed to play almost anything you throw at it - now I find out that it doesn't like old wavs, old wmvs, avis from video cameras, some mpg files, and now this issue! What next "aaarghhh!" (frustrated!). I am starting to feel like I need to re-encode everything specially for the Mede8er, just to be safe.  Shocked
Thank you so much for your time and trouble in helping me out. I am very grateful! You guys rock!  Grin
the-osiris
« Reply #14 on: October 23, 2011, 08:35:48 am »
Using handbrake 0.94 (not v0.95 - it has indexing problem) - you may choose normal profile, and MKV container (or MP4 container)
http://www.mede8erforum.com/index.php/topic,10.0.html
Handbrake v0.94 : http://sourceforge.net/projects/handbrake/files/0.9.4/
Media player like mede8er using strict rule for decoding, and those encoder seems only good for playing movie from PC which has more flexible rule
It also depend on which profile do you choose, some unmatching profile will not play on mede8er
see point 1 Smiley
not only mede8er if you say so, with different player (with same chipset) will suffer the same. they have the same SDK from realtek, and codec rules will apply for them
MED450X2 V2.0.7 :p
MED1000X3D V2.0b
LG 42LE5500 HDMI
Pages: [1] 2 3   Go Up
