The "Display" button usually cycles through 3 displays. (I'm assuming 2 if no wifi present)
Display 1: index, time, size, filename
Display 2: stream info
Display 3: signal intensity
This is the first time I've seen this, but the display cycling started showing up out of order.
showing signal intensity first, then index, then stream info.
I'm not sure what started it and it did eventually go back to the correct order.
It's possible that mixing display and pause may have started it.
