Pages: [1] 2   Go Down
Author Topic: [ TIPS ] How to upgrade YAMJ and Y2M if there's a new version available.  (Read 5821 times)
the-osiris
B8a Tester - 1000X3D
« on: August 08, 2011, 08:58:50 pm »
[WARNING] since there's new Y2Mbeta8 - you may use this full-package @ http://www.mede8erforum.com/index.php/topic,7813.0.html
IMDb keeps changing their site, that's why YAMJ has always update theirs.
This tips is to maintain YAMJ and Y2M into latest stable build available.
This folder structure is relative to yours, but I prefer this way to make it easier to update YAMJ.
Folder List :
C:\YAMJ  --> YAMJ root, contain YAMJ
C:\YAMJ\Mediainfo --> Mediainfo CLI
C:\YAMJ\Y2M --> YAMJ to Mede8er -- Run YAMJ_To_Mede8er.exe (or create shortcut to this to desktop)
Just remember for minimal requirement (YAMJ, Mediainfo CLI, and Y2M).
Download latest stable YAMJ here : http://code.google.com/p/moviejukebox/downloads/list
or download latest development build here : http://mediaplayersite.com/YAMJ_Latest
YAMJ contains several folders :
lib
mediaInfo --> MediaInfo CLI folder
notices
properties
skins --> YAMJ Skin
Download also latest stable Mediainfo here : http://mediainfo.sourceforge.net/en/Download/ (select CLI version - extract to Mediainfo folder inside YAMJ)
Download latest Y2M here : http://www.mede8erforum.com/index.php/topic,6611.0.html
Filelist (Y2MB8 Latest Build) :
Awesomium.dll
AwesomiumDotNet.dll
AwesomiumDotNet.xml
IKVM.OpenJDK.Charsets.dll
IKVM.OpenJDK.Core.dll
IKVM.OpenJDK.Text.dll
IKVM.OpenJDK.Util.dll
IKVM.OpenJDK.XML.API.dll
IKVM.Runtime.dll
ObjectListView.dll
saxon9he-api.dll
saxon9he.dll
YAMJ_To_Mede8er.Controls.dll
YAMJ_To_Mede8er.exe --> Make this shortcut to desktop
[ UPGRADING YAMJ ]
To avoid any error after upgrading YAMJ, better use different folder to current YAMJ,
[1]. Extract YAMJ to new folder - eg. C:\YAMJ_New
[2]. Extract Mediainfo CLI to C:\YAMJ_New\mediaInfo
[3]. Extract Y2M into C:\YAMJ_New\Y2M
[4]. If you have custom skin in your previous YAMJ/Y2M, just copy skin folder (skins is located at C:\YAMJ\Skins)
[5]. Try it by double click on YAMJ_To_Mede8er.exe inside C:\YAMJ_New\Y2M (set your YAMJ settings first)
[7]. If there's no error, delete your OLD YAMJ, rename YAMJ folder to C:\YAMJ
[8]. Create Y2M shorcut to your desktop - then you're ready to go.
[ UPGRADING Y2M ]
Whenever there's new update for Y2M, just extract to C:\YAMJ\Y2M it won't affect YAMJ, afterall Y2M is a tool to use YAMJ more lot easier (to Mede8er especially).
NOTE:
If running Y2M after updating failed, delete registry entry @ HKEY_CURRENT_USER\Software\YamjToMede8er
then restart Y2M.
UPDATES :
Latest Y2M V1BETA8-YAMJ-r2891-16 Jan2012 http://www.mede8erforum.com/index.php/topic,7813.0.html
See also http://www.mede8erforum.com/index.php/topic,7827.msg49484.html#msg49484
___________________________
Credit to Peter Butler for his amazing Y2M Smiley - Omertron's YAMJ - Zenitram's Mediainfo - Mede8er Forum
« Last Edit: January 19, 2012, 04:57:53 am by the-osiris » Logged
MED450X2 V2.0.7 :p
MED1000X3D V2.0b
LG 42LE5500 HDMI
auren
B8a Tester - X2
« Reply #1 on: August 09, 2011, 04:04:47 pm »
Thank you! Smiley
Mede8er model: MED500X2
FW: V2.0.0 BETA NOV11
Internal hard disk: Yes
Internal hard disk make/model/size/type: WD500AAJS 500Gb 3.5" SATA
Is your Mede8er networked: No
Type of network: N/A
Display type make and model: Toshiba 40av700e LCD
Audio connection type: HDMI to TV
MarioB
« Reply #2 on: August 25, 2011, 05:39:22 pm »
UPDATE:
Since the latest stable YAMJ got problem with IMDb, and latest YAMJ build got problem with Y2MB7, you may use this YAMJ version as workaround, http://hotfile.com/dl/126433903/f57fa74/YAMJ_r2346.rar.html
I think this YAMJ version (r2346) have also problem with IMDB. To be precise, all new scanned movies showing up without plot  and genre in about.jpg (see attachment). I hope Peter will sort the issue with latest YAMJ and Y2M.
Cheers
the-osiris
« Reply #3 on: August 25, 2011, 06:09:29 pm »
Nope!
Last time check, still good as it gets Smiley
MED450X2 V2.0.7 :p
MED1000X3D V2.0b
LG 42LE5500 HDMI
BadRobot
« Reply #4 on: August 25, 2011, 08:50:24 pm »
I have the same problem, but only after copying the "default" skin from the previous version to the "skins" folder of r2346. When using the proper "default" skin for r2346 then the plot summary is included. So it appears that some tweaking for the "default" skin is needed (as shown in the pics above).
Any ideas would be welcome. I have tried playing around with some settings, but to no avail.
MarioB
« Reply #5 on: August 26, 2011, 07:41:20 am »
Nope!
Last night I put few movies in one folder, so the Y2M can scan them from scratch. The movies were :
The Adjustment Bureau
Bad Teacher
Friends with Benefits
and only first (The Adjustment Bureau) got the full about.jpg. Remaining two have the about.jpg like in my previous post.
Maybe is something with skin like BadRobot said, but is strange that some movies get full information, a some just partial.
the-osiris
« Reply #6 on: August 26, 2011, 12:16:46 pm »
I guess there's something wrong with XML plot handle with default skin.
In the attachment is some movies you've reported has plot error, but I'm just using dummy files to check plot availability.
MED450X2 V2.0.7 :p
MED1000X3D V2.0b
LG 42LE5500 HDMI
marcepa
B8a Tester - X2
« Reply #7 on: August 26, 2011, 08:24:10 pm »
I am getting lost trying to have a working set of these programs altogether. In particular you may get a default , a default_old and a default_yamj skin ... and the default skin is not the same depending on the version of the yamj pack. Why not repack evrything into a working stable set?
Another alternative is to upgrade y2m so that it supports the current version of yamj (thereby offering greater support from the official yamj site). This seems depending on Peter Butler who does not seems to be online.
I would be glad to have an official Sanji statement on that.
the-osiris
« Reply #8 on: August 26, 2011, 09:15:47 pm »
If you prefer on particular skin, just copy skin folder into YAMJ/Skins folder.
Currently, using YAMJ r2346 and Y2M is the best choise regarding some encounter error lately by both YAMJ/Y2M.
We all hope that Peter Butler will fix this, and I know he's doing it right now Smiley
MED450X2 V2.0.7 :p
MED1000X3D V2.0b
LG 42LE5500 HDMI
MarioB
« Reply #9 on: August 28, 2011, 04:14:58 pm »
Bad Teacher
Finally I have found the cause of the problem with partial movie information from IMDB... The reason was the option imdb.site=labs that I have used to get movie names in English and not in local language. After deleting this line (or setting to imdb.site=us) everything is OK again.
Cheers
marcepa
B8a Tester - X2
« Reply #10 on: August 28, 2011, 04:22:53 pm »
Thanks a lot! I did copy a skin folder (default) into YAMJ but this mixed various components of different origin, Isuppose, with the result that I had no more background and a diiferent style.
I reverted back and will wait for an official version.
Smiley
Hixxer
« Reply #11 on: September 02, 2011, 05:24:02 pm »
Hey thanks for this Osiris!
I do wish the Mede8er guys would do a "proper" release of YAMJ though, there's a lot of folder/file replication the way it is at the moment.
marcepa
B8a Tester - X2
« Reply #12 on: September 03, 2011, 10:05:29 am »
Pending an official stable release, I have switched to YADIS, less complete than Y2M but so much straightforward. Absolutely no trouble to setup and use.
marcepa
B8a Tester - X2
« Reply #13 on: September 12, 2011, 07:48:56 pm »
Still no news from Peter Butler?
What is the exact status of Y2M? Is is product supported by Med8er? If not what is the recommended product? Because it cannot advertise for functionalities that it cannot make available to its customers.
« Reply #14 on: September 12, 2011, 08:39:04 pm »
Hi marcepa,
What is your problem to get so pushing?
Y2M is a community project by Peter Buttler. It is free. The package that can be found on the forum (with the YamJ version included) still works.
We know that Peter is working on a new release, but it is as earlier said a community project.....
So that means, he works on it when he has some spare time available.....
Same goes for Yadis, Thumbgen etc.. You are free to choose whatever you like to generate movie covers.
Even free to make your own by hand if you like.  Grin
Pages: [1] 2   Go Up
