Author Topic: Unable to browse network from X2  (Read 6493 times)
Re: Unable to browse network from X2
« Reply #15 on: August 09, 2011, 07:44:55 pm »
It would if it was the one considerd to be 1 hour too fast! It would have to lose that over a few hours by runnig slower than normal.
You don't have to unplug to reset lan thoughput. Just reset the clock. I'm experimenting with disabling summer time, and adding the hour manually.
« Last Edit: August 09, 2011, 07:50:01 pm by jer1956 »
Offline 949BFN
« Reply #16 on: August 09, 2011, 07:55:02 pm »
Doesn't seem as if one can tell the exact current time on the X2 - it only displays the time the setup menu was entered (it seems). But from what I can tell, the times of the X2 and NAS are within a second from each other if not exactly the same.
Mede8er 400, 500 & 500X2
« Reply #17 on: August 09, 2011, 07:58:25 pm »
Resetting the clock isn't a solution, just a workaround. It's means you  don't have to keep removing the power.Try to see if it "corrects" the problem for you to produce more evidence that it's a clock issue.
I've been monitoring my PC transfers using Task Manager. Everthing is OK for about 5 mins, network loadings are rock solid at the same %, and then after that network loadings slope away.
I tried disabling Screen Saver, and it made no difference.
« Last Edit: August 10, 2011, 10:51:20 am by jer1956 »
« Reply #18 on: August 11, 2011, 10:56:48 am »
I decided to re-intialize my router from scratch and the situation improved. I dd  test another box and that didn't have the problem. I think I disabled drive power management before installing the drive.
