Pages: [1] 2 3   Go Down
Author Topic: [TIP] Easy Connect to your Win7 shares using guest account (Rev 2.0 or higher)  (Read 5965 times)
« on: December 24, 2009, 04:17:30 pm »
This only applies to firmware 2.0 or higher to access your PC from your mede8er
Be sure that your computer is configured with workgroupname: WORKGROUP
You can check/change this by going to windows control panel - click on the system icon. You will see workgroupname in the bottom of the screen.
First step: enable file sharing on Win7:
1. Control panel
2. Network and Internet
3. Network and Sharing Center
4. Change advanced sharing settings
5. Under Home and Work profile enable:
                 a.   Turn on Network discovery
                 b.   Turn on file and printer sharing
                 c.   Turn on sharing so anyone with network access can read and write in public folder
                 d.   Use 128-bit encryption
                 e.   Turn off password protected sharing
                 f.   Select: Use user accounts and passwords to connect to other computers
                 g. connections with home group: use user accounts with password setting, don't choose option to let Win7 control connections with homegroup.
Now goto control panel -> user accounts -> manage other accounts -> enable the guest account. (or create a new account like e.g. mede8er and give it a password if you want to use a password protected share and no guest account)
Second step:  Share desired folders on your PC for the mede8er:
1. Start Windows Explorer (Not confuse with Internet Explorer)
2. Goto the folder you want to share on one of your local discs
3. Click with right mouse on the folder to share
4. Select Share with and then Specific people
5. On pull down bar select Guest and click on add button (or add the account you made above e.g. mede8er)
6. Click on button below.
Last step: Get access from your mede8er:
1. Goto the Network menu
2. Select WORKGROUP and select the Win7 PC with ok. (or add PC in Shortcut menu as described here if you don't see workgroup and pc: http://www.mede8erforum.com/index.php?topic=47.0)
3. For user fill in: guest leave password blank and select OK or OK save to shortcut (or use the username/password you created e.g. mede8er and the password you set in this account)
That’s it. Works like a charm without the need to change any registry setting in Win7.
To access the mede8er from your PC:
- Be sure that you have switched NAS to ON in the Mede8er setup
- On your PC open the file explorer (so not the internet explorer)
- Click on the network icon and your Mede8er will show up. Click on it to browse the content of the internal disk if you have one installed
- If you don't see it, try to type \\mede8er on the input line on the top (or if you gave it another hostname type the hostname in stead)
For those still having issues after above you can try this:
Here are some further registry 'tweaks' if this doesn't work:
WARNING: This requires editing your PC's registry which, if edited incorrectly, can cause Windows systems to become unstable and unusable. So, follow the instructions below at your own risk. - we are not responsible for any damage caused by following these steps.
      1. Navigate to the following location in the registry editor.
              MACHINE\System\CurrentControlSet\Control\Lsa\
      2. On the right side, double-click on 'everyoneincludesanonymous' and change the 'Value data' from '0' to '1'
      3. Double-click on 'NoLmHash' and change the 'Value data' from '1' to '0'
      4. Navigate to the following location in the registry editor:
              MACHINE\System\CurrentControlSet\Services\LanManServer\Parameters
      5. Double-click on 'restrictnullsessaccess' and change the 'Value data' from '1' to '0'
      6. Close the registry editor
Finally, restart your PC.
Or look at this threat: http://www.mede8erforum.com/index.php?topic=1409.msg10297#msg10297
« Last Edit: May 01, 2010, 07:16:10 pm by Maasbommel » Logged
Panasonic SA-PTX5
boowks
« Reply #1 on: February 09, 2010, 04:41:46 pm »
Well, I'm trying to connect to the mede8er from my pc but this just doesn't work.
It shows up in my network, but when I try to connect to it, I just get an error.
Any idea what the problem might be?
« Reply #2 on: February 09, 2010, 11:26:51 pm »
Maybe if you give some more details we can give it a guess what the root cause is of your problems.....
So at least to get a clue please answer all the questions below:
1 how did you connect your mede8er on the network, wifi, lan cable to a router or direct connect to your PC?
2 what firmware version on mede8er are you using
3 did you have an internal disk in your mede8er and if so is it formatted from mede8er menu
4 do you see the internal drive over the network? If yes, is it called C or HDD1
5 are you using dhcp or manual ip configuration? Please give ip address of your mede8er, pc and used subnetmask on both.
6 are you able to ping the ip address of your mede8er
7 what error message do you get when you try to connect
Panasonic SA-PTX5
boowks
« Reply #3 on: February 10, 2010, 02:08:09 pm »
Well, today it seems to be working fine.
Could the problem have been that I didn't restart the mede8er after I changed some network settings?
Anyways, it's fine for now. Hopefully it stays that way.
Thanks!
« Reply #4 on: February 10, 2010, 02:10:50 pm »
Yes, could be.
Sometimes a router holds old settings and you get some strange problems.
Power cycle router also often give a solution when haven weird network connection problems is my experience...
Panasonic SA-PTX5
KiwiXL
« Reply #5 on: February 20, 2010, 01:38:40 pm »
Hi!
I followed all your instructions, again. But the Mede8eter recognizes my PC, it shows up in the Workgroup folder, but the Harddrive I'm sharing doesn't show up. It used to show-up before. Do yuo know what the problem can be?
Thanks!
Patrick
« Reply #6 on: February 20, 2010, 02:22:59 pm »
Hi!
Thanks!
Patrick
Double post.... http://www.mede8erforum.com/index.php?topic=1280.0
Panasonic SA-PTX5
SCAGE
« Reply #7 on: March 17, 2010, 11:13:44 pm »
This was the solution. tnx!
« Reply #8 on: May 04, 2010, 06:16:28 pm »
Because of a lot of request by PM of Dutch guys, I place a translation in Dutch howto configure filesharing from mede8er to the PC... That is the only translation I am gonne do, so please no other translation requests.
I leave that to others....
Cheers,
Here it comes:
Bestanden afspelen vanaf een gedeelde folder op een pc
Stap 1: stel de werkgroupnaam van je PC in op WORKGROUP
1. klik op de start menu button - klik op computer
2. klik bovenaan op systeemeigenschappen
3. onderaan zie je Werkgroup. Hier achter dient WORKGROUP te staan
4. indien iets anders. Klik op instellingen wijzigen. In het computernaam scherm wat nu opent, klik op wijzigen.
Vul in bij Werkgroup: WORKGROUP
Doe dit met allemaal hoofdletters. Klik nu op ok. De computer opnieuw opstarten.
Stap 2: Filesharing aanzetten
1. klik op de start menu button - klik op configuratiescherm
2. klik op Netwerkstatus en -taken weergeven
3. Netwerk (naast het huisje) moet op Thuisnetwerk staan. Indien niet, klik erop en wijzig dit.
4. klik op Geavanceerde instellingen voor delen wijzigen. Selecteer daarna de volgende instellingen onder het Thuis of werk profiel (huidig profiel):
- Netwerkdetectie inschakelen
- Bestands- en printerdeling inschakelen
- 128-bitsversleuteling gebruiken
- Met wachtwoord beveiligd delen inschakelen
- Gebruikersaccounts en wachtwoorden gebruiken om verbinding met andere computers te maken
Stap 3: Gebruikers account met password aanmaken
2. klik op Gebruikersaccounts toevoegen of verwijderen
3. klik op Een nieuw account maken
4. voer op de invulregel de gebruikers naam in: mede8er
5. selekteeer Standaardgebruiker
6. klik op Account aanmaken
7. klik op de icoon met de naam mede8er
8. klik op Een wachtwoord instellen
9. vul bij Nieuw wachtwoord in: mede8er
10 vul hetzelfde in op de Bevestig regel
11. klik op wachtwoord instellen
Stap 4: folders delen die je zichtbaar wil maken vanaf je mede8er
2. klik op computer
3. ga naar de folder die je wilt delen en klik met je rechter muisknop erop
4. in het menu dat opent, selecteer Delen Met en dan specifieke personen
5. klik nu op het pijltje rechts naast de invoerregel en selecteer de gebruiker: mede8er
6. klik op toevoegen
7. pas eventueel machtigings nivo aan van lezen naar lezen/schrijven als je vanaf de mede8er bestanden vanaf je gedeelde map wil kunnen verwijderen/cq. renamen. Indien je dit niet wilt, laat het dan op lezen staan.
Stap 5. gedeelde folders benaderen vanaf je mede8er
1. zet je mede8er aan
2. selecteer Media Keuze en dan Network
3. selecteer de folder WORKGROUP
4. selecteer de naam van je pc waar je de gedeelde folder(s) hebt geconfigureerd
5. in het window wat opent vul in bij Netgebruikers ID: mede8er  (afsluiten met OK)
6. vul bij in bij wachtwoord: mede8er  (afsluiten met OK)
7. selecteer OK en opslaan naar Mijn Snelkoppelingen
Je zal nu de gedeelde folders zien uit stap 4.
Mede8er interne disk vanaf PC benaderen:
1. Op je mede8er ga naar het instellingen menu
2. Selekteer Netwerk
3. Zet NAS modus op ON
4. Op je PC start Windows Verkenner
5. Open het netwerk icoon
6. Klik op Mede8er (of de hostname die je verandert hebt in het mede8er instellingen menu onder Hostnaam)
7. Je ziet nu share HDD1. Klik hierop en je ziet de inhoud van de mede8er interne disk
Panasonic SA-PTX5
EricjK
« Reply #9 on: May 17, 2010, 09:35:52 pm »
Tnks Maasbommel for the translation!!
I needed that as it turned out to be...  Roll Eyes
Greetings,
                   Eric
« Reply #10 on: May 17, 2010, 09:47:57 pm »
Thanks that my effort was worth it....  Smiley
Cheers,
Panasonic SA-PTX5
rolandvb
« Reply #11 on: June 07, 2010, 10:57:37 am »
sory but making a special guest account to have commection with the mede8er makes no sence,
it should work right away when putting dns adres and nas on om your network like version 2.02 in win 7
if you have a lot off trouible with connection wwith the new firmware,the the coinclusion is simple bug in firmware.
firmware v 2.02 works fine and suddenly new firmware and can`t acces mexded8er on merworek annymore with the same
network and settings on win 7.
the new firmware should work just like v 2.02 without nbetwork problems.
editting the rgister of windows makes also no senxce at all!
BY CURIOSITY I TRYED WAT WAS SAID AND FOLLOWED THE INSTUCTIONS STEP BY STEP AND EVEN EDITED REGISTER STILL DOES NOT WORK !!!!!
PLEASE REWRITE THE NEW FIRMWARE SO THAT IF WORKS ON NAS AS  VERSION 2.02 Lips sealed
Mede8er/Gigabit Lan/Samsung 107 cm plasma/Musical Fidelity DAC and Amp/Totem loudspeakers and subwoofer/sony surround receiver/Humax PVR.
I am just a computer and audio an movie freak Smiley
« Reply #12 on: June 07, 2010, 05:46:23 pm »
roland,
Not the right place to post this, should be posted in bug section if you want to raise attention to this with a post.
Panasonic SA-PTX5
rolandvb
« Reply #13 on: June 07, 2010, 11:06:12 pm »
I already tryed what you said but dit not work at all.
now i reformatted my mede8er again strange because it was already formatted with the firmware 2.10
now everything is working fine.
one stange thing is that teh mede8er HD is called usb 1.
it is not nessesary to make a gues acount for the medr8er,make no sence to me.
i have one account as administrator and have no extra acount to acces mede8er.
i am glad everything is working fine now,but stange that the problem was that i had to format mij HD again it was already formatted by mede8er.
grrrezz  roland
« Reply #14 on: June 07, 2010, 11:14:16 pm »
This still gives me the impression that still not ok, because it should give HDD1 over samba when formatted from gui.
If you internal disk is still not filled I would try the following (if you know howto telnet into your mede8er):
1. downgrade to version 1.2.2a
2. wipe your internal disk completely with the dd command over telnet (see link in the howto of the mede8er beginners guide)
3. format with gui using 1.2.2a
4. now upgrade directly to 3.0.2 using the method as described in the release notes
Your disk should be mentioned HDD1 over samba after that.
Panasonic SA-PTX5
Pages: [1] 2 3   Go Up
