Author Topic: Missing "about.jpg" file in some movies  (Read 375 times)
Seamus MCL
« on: July 18, 2011, 02:08:26 pm »
Hi All,
           I'm new to this forum so hopefully I'm in the correct location, I've checked around quickly to see if anybody reported a similar problem (but to no avail).
         When I processed ( with YAMJ) my library of titles everything worked beautifully for 95% of the library. When I ran "run YAMJ" it downloaded (or created) both folder.jpg and about.jpg which I then successfully transferred to my NAS ( I'm using an 400X & a NAS). However the other 5% of titles failed...partially failed I should say, When I "Run YAMJ" It finds and downloads the folder.jpg BUT no about.jpg is created. While I could possibly understand this for some titles like music videos I find it difficult to believe for other movie titles. An example I have is for the 1982 movie "Gandhi" with Ben kingsley ( & winner of 8 ocsars). I've tries this movie both with and without an NFO file (created as per user guide) & containing the link http://www.imdb.com/title/tt0083987/    but without success. Does anybody have any suggestions as to how I might resolve this ? OR where I might be able to download an about.jpg file OR how I could create a file manually, otherwise thsi is a great app and the results look the business on the mede8er.
Correction here .... I should specify that a default about.jpg file is being created (to include movie details) but not with the movie specific backround (ie: just looks like default movie theatre picture). Additionally I'm using everything with the same names (ie: folder = gandhi, file = gandhi.avi & nfo = gandhi.nfo)
Thanks in advance
Seamus Mc
« Last Edit: July 18, 2011, 02:28:43 pm by Seamus MCL » Logged
the-osiris
B8a Tester - 1000X3D
« Reply #1 on: July 19, 2011, 09:42:53 am »
hi there,
If there's no backdrop-art/fanart (this is what we call), might be your movie title is either old, or not popular (or no one is upload their backdrop-art in tmdb), but it should've always a solution, right Smiley
You can manually edit the backdrop-art BEFORE generating into about.jpg, by selecting backdrop-art pic from jukebox folder (always ended with -fanart in the filename), then you can generate about.jpg from Y2M.
some movies has no backdrop, like "Ghost 1990 (http://www.imdb.com/title/tt0099653/)" for example.
« Last Edit: July 19, 2011, 09:51:30 am by the-osiris » Logged
MED450X2 V2.0.7 :p
MED1000X3D V2.0b
LG 42LE5500 HDMI
