Pages: [1] 2 3   Go Down
Author Topic: Using WD SATA3 Drives on the MED500X2  (Read 10717 times)
Administr8or
« on: July 16, 2011, 07:20:47 am »
EDIT: 17Dec2011
IMPORTANT :The WD30EZRX Requires 2 x formats. Do not use any jumpers.
If you navigate to the Hard Drive in the Media Library and open the HDD Icon then the Drive should be shown as HDD:
We dont know about other brands and models of  SATA3 at this point but it may well be the same as the above.
Our tests show that with the 2 x formats this drive without any jumpers and with Firmware Version V2.0.2 works to specification.
(Tested with WD30EZRS)
To use WD SATA3 HDD add jumper to Pin5-6
« Last Edit: December 17, 2011, 07:13:21 pm by Mede8er1 » Logged
getsko
B8a Tester - X2
« Reply #1 on: September 12, 2011, 10:44:56 pm »
 Wink
2 x Med 500x2 + 3TB WD
1 x Med 450x2 + 128GB SSD
1 x Pioneer PDP KRP-500
2 x Pioneer PDP 428XD
1 x Qnap 859 Pro+II (24TB)
1 x Linksys E-4200 + CISCO SRW208P + WAP4410N
besim_mede8er
« Reply #2 on: September 15, 2011, 02:16:29 pm »
I did put the jumper on 5-6 and still doesn't work for me.
I have a WD disk of 3To Caviar Green (WD30EZRX).
I have no solution from the mede8er support. They told me to use another disk.
Please help
« Reply #3 on: September 15, 2011, 03:45:02 pm »
Hi besim,
Have you tried to place this jumper and then do a reformat of the drive?
besim_mede8er
« Reply #4 on: September 15, 2011, 05:48:32 pm »
Yes I did it yesterday....
And the result is exactly the same.
I also noticed the X2 takes a lot of time to boot (not sure but between 3 and 5 minutes before it boot).
This is normal since it has problem to mount the disk I guess.
« Reply #5 on: September 15, 2011, 06:03:45 pm »
Could also be just a bad disk.... Have you tested it in a PC to see if it is working normally?
DKHG
« Reply #6 on: September 30, 2011, 05:31:17 am »
For this issue I go back to use 1.0.1 it's work fine and some feture from .2 and .3 appear on FW 1.0.1 also  Wink Wink
I hard to fine HDD jumper hear. I will wait for .4
tangigi
« Reply #7 on: October 27, 2011, 12:06:40 pm »
I bought the same drive (WD30EZRX). It didn't work the first time I format it, but I decided to change the jumper pin (I have some blue ones and some black ones) and format it again. the HDD drive was visible when I searched media file. I connected the blue usb cable to the main usb port on the Mother Board and it worked!
file space is 2.72. yay!
lar
Window 7 pc
« Last Edit: October 27, 2011, 03:43:13 pm by tangigi » Logged
MED500X2
Internal Drive: Western Digital 3TB (WD30EZRX)
Win7 64bit
JPF
« Reply #8 on: November 07, 2011, 06:44:37 pm »
It suggests that the jumpers are for the WD30EZRX, because it is written on top of the picture (6.0 Gb).
When you add the jumper to this disk, it will go down from 6.0 Gb speed to 3.0 only.
On the other hand, the WD30EZRS will go down from 3.0 Gb to 1.5.
So, the jumper setting is only usefull for the WD30EZRS.
For now, the WD30EZRX will not work at all in the 500X2 !!!
I hope Mede8er will release the right firmware soon, so the X2 Sata controller can handle the Sata-3 speed without problems in the future. Than we can mount the WD30EZRX too (with a jumper).
(The 500X2 now can only handle 1.5 Gb speed)
« Last Edit: November 07, 2011, 07:14:18 pm by JPF » Logged
« Reply #9 on: December 08, 2011, 11:24:59 pm »
Guys,
do you still see the issues with the latest firmware version on your disk with the jumper on it?
JPF
« Reply #10 on: December 11, 2011, 12:32:39 pm »
Answering questions at the Mede8er forum seems to be difficult last months...
I am using a WD30EZRS without jumper now.
So, SATA II, or 3 Gb/s if you prefer.
Maybe someone else can aswer my question:
my new disk is formatted in a very funny way bij the 500X2.
15,98MB unallocated - 2,724TB formatted - 15MB unallocated - 118MB Local, unformatted - 16MB unallocated.
Is this normal???
« Last Edit: December 11, 2011, 07:01:05 pm by JPF » Logged
« Reply #11 on: December 11, 2011, 12:51:42 pm »
What did you use to find that information?
Yes...answering problems  has got more diffiuclt...becuase we try to make sure as much information as possible is readily available in Guide and Tips. So it's those  problems for which we have no ready answer that get asked directly most, and they are the ones which often still have no answer. If you post one of those...you can feel as if you  are being ignored.
« Reply #12 on: December 11, 2011, 12:59:42 pm »
I am using a WD30EZRS without jumper.
Is this normal???
This looks normal. the 118mb is probably the linux swap partition.
JPF
« Reply #13 on: December 11, 2011, 06:54:18 pm »
Jer and Maasbommel;
I used Acronis Disk Director 11, which normally shows linux swap partitions too.
In this case it says unallocated and unformated, so I do not understand.
With the MED500 (V4.04) it was rather clear that there were 3 linux partitions, with the 500X2 it is not.
By the way, till now it´s only an empty disk, brand new and only formatted by the 500X2 with V2.02. Don´t want to loose 48 hours copying before I´m sure it is allright...
And I´m not complaining about you 2 guys. I just noticed there are more forum users complaining and questioning than answering, than we had before.
« Last Edit: December 12, 2011, 07:36:23 am by JPF » Logged
« Reply #14 on: December 11, 2011, 07:41:23 pm »
I'm glad you told us how...becuase I used to use telnet to find that out!  So was this in slave mode?
Pages: [1] 2 3   Go Up
