Author Topic: MKV plays 3 times as fast as normal  (Read 359 times)
saskir
B8a Tester - X2
Senior Member
« on: July 02, 2011, 09:09:15 pm »
Lately I have with a mkv (or more some mkv's a strange issue). It plays 3 times faster as normal. The strange thing is, that it plays it normal in the preview, this only happens when I play the files normally. Rewing, forward or CM Skip are not helping. Anyone any idea what could be the cause. Maybe the Video-Profile?
Here is the mediainfo:
General
UniqueID/String : 207662440474780579535484861661311872266 (0x9C3A54CC5F99A59F27C2344C218F2D0A)
CompleteName : G:\Instruct 021.mkv
Format : Matroska
FileSize/String : 348 MiB
Duration/String : 24mn 12s
OverallBitRate/String : 2 012 Kbps
Movie : Instruct Episode 21
Encoded_Date : UTC 2010-12-04 17:41:51
Encoded_Application : mkvmerge v3.4.0 ('Rapunzel') gebaut am May 15 2010 05:00:31
Encoded_Library/String : libebml v0.8.0 + libmatroska v0.9.0
Attachment : Yes / Yes / Yes / Yes / Yes / Yes
Video
ID/String : 1
Format : AVC
Format/Info : Advanced Video Codec
Format_Profile : High@L5.0
Format_Settings_CABAC/String : Yes
Format_Settings_RefFrames/String : 11 frames
CodecID : V_MPEG4/ISO/AVC
Width/String : 1 280 pixels
Height/String : 720 pixels
DisplayAspectRatio/String : 16:9
FrameRate_Mode/String : Variable
FrameRate/String : 23.976 fps
ColorSpace : YUV
ChromaSubsampling : 4:2:0
BitDepth/String : 8 bits
ScanType/String : Progressive
Title : H.264
Language/String : Japanese
Color primaries : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
Transfer characteristics : BT.709-5, BT.1361
Matrix coefficients : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177
Audio
ID/String : 2
Format : FLAC
Format/Info : Free Lossless Audio Codec
CodecID : A_FLAC
BitRate_Mode/String : Variable
Channel(s)/String : 2 channels
ChannelPositions : Front: L R
SamplingRate/String : 48.0 KHz
BitDepth/String : 16 bits
Title : FLAC 2.0
Encoded_Library/String : libFLAC 1.2.1 (UTC 2007-09-17)
Text
ID/String : 3
Format : ASS
CodecID : S_TEXT/ASS
CodecID/Info : Advanced Sub Station Alpha
Compression_Mode/String : Lossless
Title : Styled Subs
Language/String : English
« Reply #1 on: July 02, 2011, 09:22:48 pm »
Have seen some simular posts in the past, see:
http://www.mede8erforum.com/index.php/topic,4849.0.html
http://www.mede8erforum.com/index.php/topic,5075.0.html
saskir
B8a Tester - X2
Senior Member
« Reply #2 on: July 02, 2011, 11:43:57 pm »
Sorry didn't find them via the search (should have used the searchterm "faster").
