Author Topic: FTP ?  (Read 4398 times)
Offline Lycana
FTP ?
« on: June 30, 2011, 06:16:13 pm »
I didnt get a connection to the mede8er via ftp !
I use anonymus login witrh port 21, but there is no connection, which login data i have to use ?
I found nothing at menu or in the manual about ftp!
sry 4 the bad english
Re: FTP ?
« Reply #1 on: June 30, 2011, 07:01:25 pm »
I don't think there is an FTP server in the X2. It went, along with Telnet.
Offline Lycana
Re: FTP ?
« Reply #2 on: June 30, 2011, 07:14:13 pm »
First why not ? The 500x have on !
Second, what is the best method to get movies on the internal hdd ?
Re: FTP ?
« Reply #3 on: June 30, 2011, 07:55:53 pm »
Any back doors by which the firmware can be cloned for use on other players has been removed. The 500x firmware has been cloned for all kinds of players, non of whose users paid Sanji.
Best depends upon you situation. I have mine networked and I have no problem setting up my PC to copy via network over night.
Offline Lycana
Re: FTP ?
« Reply #4 on: June 30, 2011, 08:24:24 pm »
I have a Synology NAS, it works fine, i can see the movies on the nas via the mede8er, but i didnt get a connection from my pc or nas to the mede8er to get movies on the internal hdd. how do you solve this ?
Re: FTP ?
« Reply #5 on: June 30, 2011, 08:38:09 pm »
You have to enable the NAS function in the X2 sertup. This is a Samba NAS, not NFS.
Offline Lycana
Re: FTP ?
« Reply #6 on: June 30, 2011, 09:14:12 pm »
NAS Mode (Off / On)
Set this option to On if you have an internal disk in your Mede8er and you want to be able to access it over the network.
When enabled you can reach your Mede8er by browsing to it in Windows File Explorer under the network icon.
Or you can type \\hostname in your Internet Explorer window (e.g. \\mede8er if you left the hostname setting on default).
I do and use firefox, nothing happen, i didnt get the mede8er. Is there a tool or something to test it ?
Re: FTP ?
« Reply #7 on: June 30, 2011, 09:41:41 pm »
With firefox this will not work. Only with Internet Explorer.
What operating system are you using on your pc?
You can also type the same in the windows command line (windows keyboard button + r)
« Last Edit: June 30, 2011, 10:01:36 pm by Maasbommel »
Re: FTP ?
« Reply #8 on: July 01, 2011, 10:00:52 am »
We would also be nearer undestanding your problem if you can help prove you have a proxy DNS server in your router. This is the most common cause of  netowrking problems with recent firmware. To do that we need to know your PC operting system ,and the make/model of your router.
Offline Lycana
Re: FTP ?
« Reply #9 on: July 02, 2011, 11:20:48 am »
Hello, it works now
i use the windows command line. Is there be a tool or something to transfer the files. Because Windows sometimes have Problems with bigger files.
Re: FTP ?
« Reply #10 on: July 02, 2011, 11:36:03 am »
Google for TeraCopy and install that.
It integrates with Windows File Explorer and works great.
