Author Topic: [TIP] How to play all music contained in a folder & subfolders  (Read 2150 times)
Insomniac
Moder8or
« on: June 04, 2011, 06:26:17 pm »
For those who wish to play their collection of music from folder level there is a simple procedure:
Change to 'Music' filter; select desired folder; press PLAY
Detailed steps:
  o Press MENU on the remote;
  o Navigate DOWN & select the 'Music' option;
    Mede8er is now in 'Music' mode - only music files, playlists and folders will be visible
 o Navigate to folder or subfolder containing the music collection you wish to play;
  o Press PLAY on the remote.
The Mede8er will add all music files contained in the selected folder and subfolders to a playlist and commence playback.
« Last Edit: June 05, 2011, 03:01:35 am by Insomniac » Logged
