Hello. I am trying to add some new icons to my 500x2 videowall but had a couple questions. First I download the files and save them as .jpg? If so I am having trouble trying to get from .png to .jpg. Is there a program I need to use? Second I was trying to get some of your icons with the different backgrounds but I can't get them off photobucket.
For genre icons you should just keep the files as .png files. If you are getting them from my Photobucket album, just copy the direct link and paste it into your browser. Then once the image is displayed right click and "Save Image As" and it should want to save it in the same format as the file is stored, i.e. .png. If it comes up as .jpg, just change the file type to .png.
The same goes for the moviesheets, except they have to be .jpg files to work as about.jpg images in their respective folders. In this case do the sae as above, but just save as .jpg files.
Alternatively you could just download the complete album or .rar files that are linked in the first and second posts of this thread.
I hope that helps.
Lastly I grouped some of my movies together like Drama/Suspense and Action/Adventure and one I noticed has not been requested yet = Period Movies (i.e 300, Thor, The Eagle, Centurion) . Any chance you can do those ones I mentioned? Thanks for your help.
I will do a genre icon for "Period Movies"
