Author Topic: Synopsis not showing on my movies ?  (Read 548 times)
Luckycharms_74
« on: May 22, 2011, 04:22:23 pm »
Hi All
I have ran the Y2M for my hard drive and it has created info and cover art for 90% of the files. When I browse the files on the player it just shows the cover art but not the detailed synopsis. I have checked the hard drive on my PC and it has created an index in HTML document. When I click on that is shows each movie and synopsis. How do I get this to work on my player Sad.
I have attached the HTML Index.
Then when I click on any movie the synopsis will come up like this below.
Does the media player need internet access to get the HTML files or am I doing something wrong in the setup  Huh
the-osiris
B8a Tester - 1000X3D
« Reply #1 on: May 22, 2011, 06:26:01 pm »
Using Y2M will generate two files in movie folder, about.jpg and folder.jpg.
about.jpg is backdrop-art with synopsis ect, and folder.jpg is just simply movie cover-art.
While browsing using Media Library, folder.jpg will show up in every movie folder, pressing SLOW/A-B button in the remote will reveal about.jpg
Y2M only need internet connection to get movie info, Mede8er only need those two files (Y2M will generate them)
I suggest you to read manual, here in my footer  Smiley
MED450X2 V2.0.7 :p
MED1000X3D V2.0b
LG 42LE5500 HDMI
Luckycharms_74
« Reply #2 on: May 22, 2011, 11:42:29 pm »
Thanks for the heads up. I also did not have folders created for every file so once I did that it worked great.
Just some files have wrong dats , I guess I have to manually edit them   Tongue
