Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
Username :
Password :
March 29, 2024, 04:53:49 AM
News:
Click here
to go back to the Mede8er Official website.
Home
Help
Search
Login
Register
Mede8er Forum
Mede8er Products
MED500X2/MED400X2/MED400X2S/MED450X2/MED450X2S
Technical Issues
Video Wall resolution
« previous
next »
Pages: [
1
Go Down
Author
Topic: Video Wall resolution (Read 5400 times)
beginnersluck
Helpful Contribution Status: +0/-0
on:
May 05, 2011, 12:30:29 PM »
I must say that Videowall really is a great item, however, somewhat pity that the pictures are restricted to a maximum of 75kb, I have a big screen TV (46 inch) and the pictures are fuzzy... (or did I do something wrong?)
M8er Addict
Helpful Contribution Status: +51/-8
Re: Video Wall resolution
Reply #1 on:
May 05, 2011, 04:08:35 PM »
The size is small to get a good load speed. It is a good trade off....
Some questions:
- how do you generate the folder.jpg files?
- what video setting do you use on your mede8er?
- and how close are you sitting to your big screen?
Probably too close....
Read the
Mede8er 400X/500X Beginners Guide
or
Mede8er 500X2/400X2/450X2 Beginners Guide
Also check the
Couto X3D Newbies Guide
first.
the-osiris
B8a Tester - 1000X3D
Reply #2 on:
May 05, 2011, 09:23:18 PM »
Maybe it's too pixelate, too small, or too hard to read, but if you want to see movie title, there are folder name in both top/bottom of the screen. And navigating videowall is only small part while playing Mede8er
Mede8er Support Page
Mede8er Product Matrix
MED450X2 V2.1
MED1000X3D V2
LG 42LE5500 HDMI
beginnersluck
Reply #3 on:
May 07, 2011, 05:17:39 PM »
Well, first I run YAMJ, and then I notice the best pictures to use are between 250 and 500 kb (not the booklet pictures but the "background" pictures with all the info on it), so I reduce them with pixresizer so they are not larger than 75 kb.
With 75kb you can simply not get a good enough resolution to project on a large screen (and no, I'm not to close to my screen...
M8er Addict
Reply #4 on:
May 07, 2011, 06:49:47 PM »
Reading your comment I get the impression that you are talking to reduce the about.jpg files to max 75kb?
That is not needed. The 75kb limit is only for the folder.jpg files and not for the about.jpg files.
In my config most folder.jpg files are between 50kb and 75kb.
The about.jpg pictures are around 300kb to around 500kb
If you use YamJToMede8er it will generate these pictures for you around this size.
Read the
or
Also check the
first.
Pages: [
1
Go Up
« previous
next »
Mede8er Forum
Mede8er Products
Technical Issues
